How to use OCM for dual cores on zynq
I'm trying to run both cores on zynq under system debugger. However, when I run both cores, core0 behaves weird. It seems run to a weird place.
I check the assemble code, it is weird too.
However, when I run core0 alone, it is normal:
here is my two linker.ld for core0 and core1:
The .text is located in ram_0 and ram_1, all other sections located in ddr.
If I change the .text in core0 to ddr, both cores can run normally. So I guess it's a problem of ocm allocation.
Is there anything wrong with my linker file? Any rules or constraints in using ocm??
Best Regards
Re: How to use OCM for dual cores on zynq
Thank you, @cch
I've read xapp 1079, however it does not help me much. Since the example design doesnot use OCM much, only use as a global sync flag. And I don't see any helpful info when I read the linker script of this example.
I'm using SDK 2017.4. bare-metal on both cores. My goal is to use a part of  OCM as shared memory between two cores and the other part of OCM is divided by two cores as two private memories.
I changed my linker script of core1 , the only difference from the linker.ld in my last post is that I changed ps_ram_1's base and size to 0x20000 and 0x10000. The linker.ld of core0 stayed the same as my last post shows.
The weird behavior on core0 has gone. But I still don't see the real problem.
Can you help me with this?
Best regards
The cores are not completely independent, they are part of a cluster that share resources.
Take a look at XAPP1079 which provides information on how to run a bare metal AMP system on Zynq-7000.
Christophe
Thank you, @cch
Best regards
There are no issues sharing the OCM as long as your linker script for each core does not overlap.
A couple things to keep in mind:
  1. Make sure to use the symbol "USE_AMP" when compiling for core 1
  2. The OCM map out of reset is:0x0 to 0x2_FFFF (192KB) and 0xFFFF_0000 to 0xFFFF_FFFF (64KB). Some locations in the higher OCM are used to keep core1 in WFE state. Refer to Chapter 29 of the TRM
If you are seeing runtime issues I would recommend stepping through your code to see what is happening.
Christophe
