Visitor helena
How to use data from file in a bare metal application?
I'm using Zybo board for a project and I have a binary file with the input data for the algorithm I'm using. The application is bare metal, I'm not using any OS (or can). I've read in a few posts that the UART could be used to do this but I can't get it to work. I needed to put the data from the files in memory and in the end I need to export the output into a file as well.
I'd truly appreciate if anybody could help me.
Scholar hbucher
Re: How to use data from file in a bare metal application?
@helena you can use the console XSCT to read from file and write to memory
See page 26
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_2/ug1208-xsct-reference-guide.pdf
Scholar hbucher
See page 26
Visitor helena
Thank you! This worked!
