I2C Slave address Si570 on ZC702 board.
Hi, there
I am reading up the slides on how to program the XTP181 ZC702 Si570 Programming.
My idea is to directly write to the Si570 to change the output frequency.
The XTP181 source code writes to EEPROM instead of the Si570 itself. And the Si570 datasheet says the "The device I2C address is specified in the part number.". I cant seem to get the number.
How can I get the address?
Re: I2C Slave address Si570 on ZC702 board.
Thank you htsvn and gnarahar.
I guess it's 5D since the si570_programming.c works on my board and the address in the source code uses 5D.
@lis_user1 From the BOM, the part# is 570BAB000544DG . Input that here
http://www.silabs.com/VCXOPartNumber/Pages/default.aspx
You will get the I2C address as 5D (hex)
- Giri
hi,
this information is available in the schematic. Refer to the page 2 of http://www.xilinx.com/support/documentation/boards_and_kits/zc702_zvik/xtp185-zc702-schematic-rev1-1.pdf
snapshot attached.
--hs
