ILA cross trigger doesn´t work
I have a design with an AXI4Lite Bus and an ILA attached to that bus:
The configuration of the ILA looks like this:
I generate a bitstream, export the bitstream to the SDK and write my application software:
#include "xgpio.h"
#include "xparameters.h"
u32 Counter = 0x06;
u32 Status = XST_SUCCESS;
XGpio Gpio;
int main()
	Status = XGpio_Initialize(&Gpio, XPAR_LED_DEVICE_ID);
	if(Status != XST_SUCCESS)
		xil_printf("GPIO Initialization failed: %lu\r\n", Status);
		return XST_FAILURE;
	while(1)
		XGpio_DiscreteWrite(&Gpio, 1, Counter);
		for(u32 Delay = 0; Delay < 0xFFFFFF; Delay++);
		XGpio_DiscreteClear(&Gpio, 1, Counter);
		if(Counter < 0x0F)
			Counter++;
		else
			Counter = 0x00;
		xil_printf("Counter: %lu\n\r", Counter);
	return 0;
Now I create a new debug setting:
I launch this debug settings and wait for the debugger to jump at the entry point at "main". Now I open the hardware manager in Vivado, connect to my target, add the signals to the ILA and change the trigger mode to "TRIG_IN_ONLY" :
Now the ILA got armed by clicking "Run trigger for this ILA core" and after that step I resume my application (F8) to jump to a breakpoint at
but my ILA doesn´t trigger. The status is "Waiting for Trigger".
So what is wrong with my settings?
Re: ILA cross trigger doesn´t work
Okay I think I found the solution for the problem. It seems that I have to switch the Cross Trigger settings in my debug configuration.
Why do I have to set "CPUDBGACK0" as input and the "FTM trigger" as output? I want to hold the ILA when a break point is hit. So I assumed that the signals should go from the CPU to the ILA and not from the ILA to the CPU.
Can someone explain this to me?
Thank you!
