Newbie vic21x
IP core 8 bit divider help
could someone please help me on creating the following or where can I find resources to achieve and understand this?
program that given an 8 bit number, it generates the 3 digits BCD that represent hundreds, tens and units in it.
create a
This program must employ in it's design an IP core to run divisions. To run a simulation of this program on the spartan 3e kit, an 8 bit number must be defined inside the program, and show the 3 outputs via LEDS, this using the interruptors (SW3, SW2, SW1) like this: if the input signal in the interruptors SW3,SW2,SW1 is 001, show the units, if it is 010, show the tens and if it is 100, show the hundreds.
program that given an 8 bit number, it generates the 3 digits BCD that represent hundreds, tens and units in it.This program must employ in it's design an IP core to run divisions. To run a simulation of this program on the spartan 3e kit, an 8 bit number must be defined inside the program, and show the 3 outputs via LEDS, this using the interruptors (SW3, SW2, SW1) like this: if the input signal in the interruptors SW3,SW2,SW1 is 001, show the units, if it is 010, show the tens and if it is 100, show the hundreds."
thanks and have a good day
Re: IP core 8 bit divider help
I would suggest meeting with your professor to discuss the requirements in more detail if you do not understand this or are looking for direction.
bt
