Visitor mohit.tomar
IPs for Microblaze MSC
HI,
Is there any IP which can interface with Microblaze MSC?
I want to interface multiple UART with Microblaze MSC. As Microblaze MSC support only one UART port and IO bus port also. can i used IO bus port for interface multiple UART IP?
Re: IPs for Microblaze MSC
Hi @mohit.tomar,
Please try using AXI Uartlite or AXI Uart16500 IPs for the purpose to interface with MCS.
Praveen
Visitor mohit.tomar
Hi Praveen,
How can we interface AXI Uartlite with MCS, as MCS don't support AXI Interface?
Hi @mohit.tomar,
Please refer to this post:
https://forums.xilinx.com/t5/Embedded-Processor-System-Design/Microblaze-MCS-to-AXI-lite/td-p/662917
Here it's explained about Microblaze MSC to AXI lite interface using IO bus. Create a bridge IP between IO Bus and AXI lite interface.  once you created then you are free to add many peripherals like uarts, i2c, xadc, etc to your Microblaze MSC.
Best Regards,
Srikanth
