Newbie xianle_wang
If I only use XCZU19EG PL and not use PS,how to connect power and reset and other signals
If I only use XCZU19EG PL and not use PS,how to connect power and reset. especially the power on RESET and SRST.Because I don't want to use PS,can I pull down the power on reset (V23)directly? I can reset PL at the same time? and the SRST can make PL reset?  The PS_REF_CLK is necessary ? the FPGA temp sencer can be used?
Scholar jg_bds
Re: If I only use XCZU19EG PL and not use PS,how to connect power and reset and other signals
So what I hear you saying is, someone gave you a ZU19EG:
but what you really wanted was a KU15P:
Given all the grief and aggravation it's going to cost you, wouldn't it be easier to simply get the right chip?
-Joe G.
You must use the PS.  The PL is not enabled and not programmable without the some basic setup by the PS.
The PL has no fundamental user reset just the configuration init (connected to PROG_B in FPGA only devices) and user resets (which can be connected to any user pin) .  I believe the SRST can be connected to the config init but not as a user pin to the PL
