Visitor mgago2013
Iicps library, using ZedBoard as a master device
Hello
First of all, I am a newbie so I hope I am writing this in the correct pace.
I am trying to receive data using i2c from the specific register of the slave device with the 7bit address of 0x42 (0b1000010X, where X is R/W bit). As a master device I am using PS side of the ZYNQ on the ZedBoard. I decided to use iicps library from Xilinx SDK.
Generally, in i2c reading is done as fallows:
Write data first:
<I2C slave address><get ACK><register address><get ACK>
Then Read:
<I2C slave address><get ACK><received data><NACK>
blue is done by master and red by slave.
This is my script:
#include <stdio.h>
#include "platform.h"
#include "xparameters.h"
#include "xiicps.h"
#define IIC_DEVICE_ID		XPAR_XIICPS_0_DEVICE_ID
#define IIC_SLAVE_ADDR		(0x84>>1)
#define IIC_SCLK_RATE		100000
#define TEST_BUFFER_SIZE	10
XIicPs Iic;		/* Instance of the IIC Device */
u8 SendBuffer[TEST_BUFFER_SIZE];
u8 RecvBuffer[TEST_BUFFER_SIZE];
int main()
	XIicPs_Config *Config;
	Config = XIicPs_LookupConfig(IIC_DEVICE_ID);
	XIicPs_CfgInitialize(&Iic, Config, Config->BaseAddress);
	XIicPs_SetSClk(&Iic, IIC_SCLK_RATE);
	SendBuffer[0] = 0x01;
	XIicPs_MasterSend(&Iic, SendBuffer, 1, IIC_SLAVE_ADDR); /*sending slave and register addresses*/
        int t = 0;
	while(t<16002)
		t++;
	XIicPs_MasterRecv(&Iic, RecvBuffer, 1, IIC_SLAVE_ADDR); /*sending slave address once again and receiving data*/
	printf("%d\n",RecvBuffer[0]);
	return 0;
This script kind of work. Here are some pictures from oscilloscope which look fine. I also checked sent and received data with the USB Logic Analyzer and everything seams to be correct.
However there are two problems which I can not solve.
1) If I decrease or erase delay (while function. delay length 6us) between send and receive function, receive function is not executed. Is this normal?  I thought that delay was not needed at all.
2) even thought slave returns correct data, XIicPs_MasterRecv function is not storing it inside of RecvBuffer and printf("%d\n",RecvBuffer[0]); always returns 0.
I am not very experienced in programming, so there is a high possibility that I am not using or understanding  iicps library correctly. This is why I am posting this here.
Thank you to everyone who will read this. I hope I have not occupied much of your time.
