Infinite loop in the function FsblHandoffJtagExit after launching FSBL
Hi there,
I debugged the FSBL I built with XSDK and found it got stuck at labe "Loop" in function FsblHandoffJtagExit (in file fsbl_handoff.S).
FsblHandoffJtagExit
		mcr	 p15,0,r0,c7,c5,0		;/* Invalidate Instruction cache */
		mcr	 p15,0,r0,c7,c5,6		;/* Invalidate branch predictor array */
		dsb
		isb							;/* make sure it completes */
	ldr	r4, =0
		mcr	 p15,0,r4,c1,c0,0		;/* disable the ICache and MMU */
Loop
	wfe
	b Loop
FsblHandoffExit
		mov	 lr, r0					;/* move the destination address into link register */
		dsb
	ldr	r4, =0
		bx		lr					;/* force the switch, destination should have been in r0 */
.Ldone
	b		.Ldone				;/* Paranoia: we should never get here */
	END
#else
Basically I want to boot Uboot by `HandoffAddress = LoadBootImage();` in main.c, but it cannot step over the line `FsblHandoffJtagExit();`.
I searched that the command `wfe` means waiting for an event. What's it? (All these codes of FSBL are automatically generated by Vivado and XSDK.)
Does anyone have points to it? Thanks a lot.
Best,
Jeremy
Re: Infinite loop in the function FsblHandoffJtagExit after launching FSBL
Please compiled FSBL with the symbol FSBL_DEBUG_INFO, then check the output log to see what address is assigned to Handoff Address.
If it’s incorrect, you can manually change it in the FSBL, something like “HandoffAddress = 0x00100000;”
Hi Ritakur,
Thanks for your reply. I enabled the option "FSBL_DEBUG_INFO" to get logs. And actually it has not reached the line to assign HandoffAddress a value. Calling function ' FsblHandoffJtagExit() ' is in front of calling 'HandoffAddress = LoadBootImage();'.
As shown in the following excerpt of main.c, it gets stuck  right after outputting "Before calling function FsblHandoffJtagExit()" to the UART terminal. The log "After calling function FsblHandoffJtagExit" doesn't appear..
	 * JTAG  BOOT MODE
	if (BootModeRegister == JTAG_MODE) {
		fsbl_printf(DEBUG_GENERAL,"Boot mode is JTAG\r\n");
		 * Stop the Watchdog before JTAG handoff
#ifdef	XPAR_XWDTPS_0_BASEADDR
		XWdtPs_Stop(&Watchdog);
#endif
		 * Clear our mark in reboot status register
		ClearFSBLIn();
		 * SLCR lock
		SlcrLock();
		fsbl_printf(DEBUG_GENERAL,"Before calling function FsblHandoffJtagExit() \r\n");
		fsbl_printf(DEBUG_GENERAL,"After calling function FsblHandoffJtagExit \r\n");
	} else {
	fsbl_printf(DEBUG_INFO,"Flash Base Address: 0x%08lx\r\n", FlashReadBaseAddress);
	 * Check for valid flash address
	 * This used only in case of E-Fuse encryption
	 * For image search
	SystemInitFlag = 1;
	 * Load boot image
	fsbl_printf(DEBUG_INFO,"(Load boot image) Handoff Address: 0x%08lx\r\n",HandoffAddress);
Using "Launch on Hardware (System Debugger)" by XSDK connected to board, I found that it was always running in the loop
FsblHandoffJtagExit:
		mcr	 15,0,r0,cr7,cr5,0		/* Invalidate Instruction cache */
		mcr	 15,0,r0,cr7,cr5,6		/* Invalidate branch predictor array */
		dsb
		isb					/* make sure it completes */
	ldr	r4, =0
		mcr	 15,0,r4,cr1,cr0,0		/* disable the ICache and MMU */
Loop:
	wfe
	b Loop
BTW, for some reason I use the Vivado 2016.4/XSDK. The board I use is Zybo-z7-20.
Did you have any idea? Thanks.
I have this exact same problem.  Why is the fsbl hitting this loop?  It seems that uboot will never launch because of this.
no one has a reply?
for me it stucks in a loop in DDynClk_SetRate.
the project is setting up Pcam-5C for zybo z7020 that am re-targetting on board zybo z7010.
Is DDynClk_SetRate a fsbl function?
The FsblHandoffExit is supose to sit in a loop forever. Since bootmode is set to jtag, xsct will download fsbl, run it for a few seconds, then stop the cpu. These actions take place so that a scripted flow can use fsbl to initialize the PS by running ps7_init.
If you were booting from SD, qspi, or other physical boot device, then FsblHandoffJtagExit is not used, and instead the cpu will jump to the execution address of the first .elf that was loaded from boot.bin.
