Instance based ELF association in RTL based IP
I have a 6-channel PHY design. Each PHY comprises of many HP IOs. Each PHY has its own MicroBlaze for calibration purpose. I want to associate ELF file to MicroBlaze individually. I want to do this because the skews in the custom board are different for each channel, and the DQS/DQ delay setting are different for each channel. Though I have different ELF file, I could not find an option in Vivado GUI to associate to specific MicroBlaze. Any quick help on this regard is greatly appreciated. I'm using Vivado 2018.2.
Robert.
Re: Instance based ELF association in RTL based IP
There are STC and STR (scoped_to_cells, scoped_to_ref) that can be applied to each ELF. So the STC is the microblaze cell, and the STR is the module name where the cell resides
Thanks Stephen. I did look that before in the TCL console, but didn't find information if I can specify the hierarchical path of MicroBlaze. Let me play around with tool. If there is an example, that would help.
