Interrupt ARM Application thorugh Microblaze over GPIO
Hello all,
how I could set an interrupt of an ARM app via MicroBlaze GPIO signal?
I have one ARM Core and one Microblaze. To the Microblaze has a AXI GPIO Block connected and interrupt is enabled. I want to set the interrupt signal over the central Button  BTNC on Zedboard.with PACKAGE_PIN P16.
I think first of all I have to enable Interrupts on ARM. Then for example a while printf loop is running.
This will be interrupted by pushing the BTNC Button which is connected to Microblaze via GPIO.
How I can run that work in SDK? Are there any examples?
Thanks in advance.
Re: Interrupt ARM Application thorugh Microblaze over GPIO
@johnmcd thanks for your reply, I just wanted to post that I could solve the problem by my own. There were some specific code lines missing to trigger the interrupt.
This post can be closed
I tried some steps, but I can't get an interrupt running. please help :(
that's my example blockdesign.
Take a look at the axi_gpio interrupt example found in your sdk install dir.
I.E: D:\Xilinx\SDK\2017.2\data\embeddedsw\XilinxProcessorIPLib\drivers\gpio_v4_3\examples
