01-09-2019 07:46 PM
In my design, the interrupt line from the timer is connected to interrupt controller.
The timer is set for a RESET value + Down count + Auto reload
When it reaches 0, it should create an interrupt.
I ran the attached code.
For some reason, I'm getting an interrupt upon timer start (which should not happen).
And then endless interrupts.
My quesions:
1. If the timer is connected to interrupt handler, should I use: XTmrCtr_SetHandler ? Why ?
2. Currently I'm connecting a handler to the interrupt controller with:
XIntc_Connect(&InterruptController, TMRCTR_INTERRUPT_ID, TmrCtr_FastHandler,(void *)0);
3. In the handler I'm calling to XIntc_Acknowledge(&InterruptController, TMRCTR_INTERRUPT_ID);
Should I do any further operations to clear the interrupt ?
Thank you in advance,
Zvika
#include <stdio.h> #include "platform.h" #include "xil_printf.h" #include "xparameters.h" #include "xil_exception.h" #include "xtmrctr.h" #include "xintc.h" /************************** Constant Definitions *****************************/ #define TMRCTR_DEVICE_ID XPAR_TMRCTR_0_DEVICE_ID #define INTC_DEVICE_ID XPAR_INTC_0_DEVICE_ID #define TMRCTR_INTERRUPT_ID XPAR_INTC_0_TMRCTR_0_VEC_ID #define TIMER_COUNTER_0 0 #define RESET_VALUE 0xF0000000 int IntCounter=0; /************************** Function Prototypes ******************************/ int TmrCtrPolledExample(u16 DeviceId, u8 TmrCtrNumber); static int TmrCtrSetupIntrSystem(XIntc* IntcInstancePtr, XTmrCtr* InstancePtr, u16 DeviceId, u16 IntrId, u8 TmrCtrNumber); void TimerCounterHandler(void *CallBackRef, u8 TmrCtrNumber); void TmrCtrDisableIntr(XIntc* IntcInstancePtr, u16 IntrId); /************************** Variable Definitions *****************************/ XTmrCtr TimerCounter; /* The instance of the Tmrctr Device */ XIntc InterruptController; /* The instance of the Interrupt Controller */ /****************************************************************************/ void TmrCtr_FastHandler(void *CallbackRef) { XIntc_Acknowledge(&InterruptController, TMRCTR_INTERRUPT_ID); IntCounter++; } /*************************************************************************/ int main() { // init_platform(); int Status; // u32 Value1; u32 Value2; XTmrCtr TmrCtrInstancePtr ; Status = XTmrCtr_Initialize(&TmrCtrInstancePtr, TIMER_COUNTER_0); if (Status != XST_SUCCESS) { return XST_FAILURE; } /*interupt*/ Status = XIntc_Initialize(&InterruptController, INTC_DEVICE_ID); if (Status != XST_SUCCESS) { return XST_FAILURE; } Status = XIntc_Connect(&InterruptController, TMRCTR_INTERRUPT_ID, TmrCtr_FastHandler,(void *)0); if (Status != XST_SUCCESS) { return XST_FAILURE; } Status = XIntc_Start(&InterruptController, XIN_REAL_MODE); if (Status != XST_SUCCESS) { return XST_FAILURE; } XIntc_Enable(&InterruptController, TMRCTR_INTERRUPT_ID); Xil_ExceptionInit(); Xil_ExceptionRegisterHandler(XIL_EXCEPTION_ID_INT, (Xil_ExceptionHandler)XIntc_InterruptHandler,&InterruptController); Xil_ExceptionEnable(); /*interupt*/ XTmrCtr_SetHandler(&TmrCtrInstancePtr, TimerCounterHandler,NULL); XTmrCtr_SetOptions(&TmrCtrInstancePtr, TIMER_COUNTER_0, XTC_INT_MODE_OPTION | XTC_DOWN_COUNT_OPTION | XTC_AUTO_RELOAD_OPTION); XTmrCtr_SetResetValue(&TmrCtrInstancePtr,TIMER_COUNTER_0, RESET_VALUE); //XTmrCtr_Start(&TmrCtrInstancePtr, TIMER_COUNTER_0); while (1) { Value2 = XTmrCtr_GetValue(&TmrCtrInstancePtr, TIMER_COUNTER_0); } XTmrCtr_SetOptions(&TmrCtrInstancePtr, TIMER_COUNTER_0, 0); //cleanup_platform(); //return 0; } /******************************************************************************/ void TimerCounterHandler(void *CallBackRef, u8 TmrCtrNumber) { XTmrCtr *InstancePtr = (XTmrCtr *)CallBackRef; }
