Is it possible to do the dynamic voltage scaling on the ZC702 board?
I using ZC702 board now. I am aware it has 5 voltage regulators.
Best wishes,
Lei
Scholar hbucher
Re: Is it possible to do the dynamic voltage scaling on the ZC702 board?
This thread
https://forums.xilinx.com/t5/Zynq-All-Programmable-SoC/Zynq-PS-dynamic-clock-control/td-p/420079
Zynq-7000 AP SoC Low Power Techniques part 5 - Linux Application Control of Processing System - Frequency Scaling & More Tech Tip
http://www.wiki.xilinx.com/Zynq-7000+AP+SoC+Low+Power+Techniques+part+5+-+Linux+Application+Control+of+Processing+System+-+Frequency+Scaling+%26+More+Tech+Tip
This paper
Dynamic voltage & frequency scaling with online slack measurement
http://dl.acm.org/citation.cfm?doid=2554688.2554784
It says in DS190 (Zynq-7000 All Programmable SoC Overview):
https://www.xilinx.com/support/documentation/data_sheets/ds190-Zynq-7000-Overview.pdf
The PS can be run at a reduced clock rate down to 30 MHz using the internal PLLs. The clock rate can be changed dynamically. To change the clock dynamically, the user must unlock the system control register to access the PS clock control register or the clock generation control register.
in UG585 (Zynq-7000 AP SoC Technical Reference Manual):
https://www.xilinx.com/support/documentation/user_guides/ug585-Zynq-7000-TRM.pdf
After the boot process and when the user code executes, the bypass mode and output frequency of each PLL can be individually controlled by software.
Scholar hbucher
This thread
This paper
