Participant welcomelm
Is it possible to expose a tx_reset signal from AXI 1g/2.5g Ethernet subsystem
For 1588 support, I need to connect m_axis_tx_ts to a datawidth converter->clock converter->axi fifo, the clock domain for m_axis_tx_ts  is tx_mac_aclk, there is supposed to be a tx_reset signal from TEMAC document, but I couldn't find it exposed from AXI 1g/2.5g Ethernet subsystem bus. Need some help to find the reset signal.
Re: Is it possible to expose a tx_reset signal from AXI 1g/2.5g Ethernet subsystem
Hi @welcomelm,
In AXI Ethernet Subsystem IP there is no tx_reset signal to Tri-Mode EMAC block.
Its just, s_axi_tx_av, gt_clk, m_axis_rx_av and mii/g,ii and rgmii ethernet interface.
There areaxi_txd_arstn and axi_txc_arstn ports.
Praveen
