Visitor gvilanovaf
Is possible connect FPD-Link III devices to Zynq IOSERDES?
Hi all,
Nowadays we use IOSERDES to connect a FPD-Link II device to Zynq and, in near future, we would like to use FPD-Link III devices. Main problem is that FPD-Link II is based on LVDS and FPD-Link III is based on CML, and I have several doubts that we can use IOSERDES for CML reception.
Anyone could confirm if is possible receive CML signals on IOSERDES?
Community Manager
Community Manager
Re: Is possible connect FPD-Link III devices to Zynq IOSERDES?
CML (Current Mode Logic ) differential IO standard is not an officially supported Standard so it is no possible to have a CML input or output pin. The key benefit of CML is its ability to tolerate common mode noise. It may possible to use LVDS/LVPECL kind of other differential IOSTANDARDS to interface with CML, this is discussed in the following application note: http://focus.ti.com/lit/an/scaa059c/scaa059c.pdf on page 11 it shows how to interface with LVDS.
Please note that transitioning between desperate I/O types can be problematic if you fail to consider their technological differences. Note that the customer should fully simulate this to ensure that the interface will work as expected.
Visitor gvilanovaf
Well, I can see that is possible.
But, Do you think that is feasible for a FPD-Link III connection @ 1,4Gbps?
Community Manager
Community Manager
Which device are you targeting? XC7Z010/020/030/045?
If you are targeting XC7Z010 or 020 then 1.4 Gb/s is not possible. See the first attachment.
If it is 030 or 045 then it is possible. Please see second attachment.
Visitor gvilanovaf
Our target is XC7Z020, speed grade -2. It's for a megapixel camera, 1,4Gbps is the higher limit.
Anyway, we can suppose 1,2Gbps, do you think that this option could be feasible?
Community Manager
Community Manager
1.2 Gb/s is possible with -2/-3 speed grade devices.
Visitor cesarproano
Is possible that you can provide me with some tips on how to implement FPD-Link II in Zynq ? is there any IP core that I can use? I am trying to connect the FPGA directly to DS90UR241 from TI.
Is there body already tried it before?
Visitor cesarproano
