Visitor zshen
Is the mali-400 GPU in MPSoC support general purpose computing?
Is the mali-400 GPU support general purpose computing (like CUDA)? Is there any such case or tutorial available?
Teacher muzaffer
Re: Is the mali-400 GPU in MPSoC support general purpose computing?
@zshen I am pretty sure mali-400 doesn't support gpgpu features and it can't be programmed with cuda.
The Mali 400 doesn't support general purpose computing.
It supports OpenGL ES 2 shaders so some very limited computing could be done if you can squeeze your code into a GLSL shader program and data into textures.
But on a Zynq it's probably going to be much better to put any code which is suited to GPUs into a custom accelerator in PL!
