Issue with Simulating the AXI GPIO core
Hi all,
I have been trying to simulate a custom host master bridge to AXI4 lite slave.  If we use our AXI4 lite test cores for the termination AXI4 lite devices the bridge works fine with no errors.  However, if we add a Xilinx AXI GPIO core and try to write (reading is fine) we find that the GPIO core does not assert the BVALID signal on the second write.  Remove all other AXI Test cores so we only  have our custom bridge connected by the AXI interconnect to only one AXI GPIO device, no problems.
If we try to use two AXI GPIO cores, the issue returns.  It looks like there is potentially an issue with the generate simulation products for the AXI GPIO.   Unfortunately, we don't have a license for the Zynq Base system Simulation device so we are unable to test (simulate)  independent of our custom hardware.
Vivado Version 2014.2
Walter
Re: Issue with Simulating the AXI GPIO core
Can you provide a testcase?
Debraj
