Observer zafirhafeez
JTAG problem in custom board
I am in the process of a custom board bring up based on zynq XA7Z020. I am not able to detect the device on JTAG. I am using usb platform cable for the JTAG connection and vivado 2016.4. I have checked all the voltages to zynq and also the crystal frequency (50 mhz). Also the jtag signals are arriving up to the resistors connected to the zynq jtag pins (checked with oscilloscope; cannot check the signals upto the bga obviously). When I select auto connect in hardware manager the cable is detected but no device is detected on the cable. The led on platform cable turns yellow as the board is powered. SRST and POR pins are at high.
Please help me what can be the reason​ for this problem.
Jwd
Tags (3)
Re: JTAG problem in custom board
I have managed to resolve the problem. The issue seemed to be with the power on sequence and reset timing. Thanks for the support
Please check all JTAG connections as per configuration user guide. Please  reduce TCK frequency and try once
What is the O/S installed in your system?
Please check whether the below minimum PC environment was there in your system or not:
The host computer must contain a USB host controller with one or more USB ports. The controller can reside on the PC motherboard, or can be added using an expansion or PCMCIA card. Xilinx USB cables support both USB 1.1 and 2.0 ports, although performance is optimal on USB 2.0 ports. For additional details, refer to the cable data sheets: Platform Cable USB Data Sheet(DS300) and Platform Cable USB II Data Sheet(DS593):
http://www.xilinx.com/support/documentation/configuration_hardware.htm
Also refer https://www.xilinx.com/support/answers/35011.html
Thanks for your reply. OS is Windows 7 64 bit. I will check with lower TCK frequency and get back with the result
