LED Problem( When Press Push Button, no LED light up)
When I tried this coding , the FPGA light up 2 LEDs.
#include "xgpio.h"
#include "xparameters.h"
#define LED_1 0x8
#define LED_2 0x4
int main(void)
  XGpio gp_out;
  XGpio_Initialize(&gp_out, XPAR_LEDS_4BIT_DEVICE_ID);
  XGpio_SetDataDirection (&gp_out, 1, 0x0);
  while (1)
    XGpio_DiscreteWrite (&gp_out, 1, LED_1 | LED_2); // Light up continuously
But the problem occur when I design a code where push button is pressed , particular LED will light up. Based on below coding, when I press, the information of which LED should be light up is displayed in the hyperterminal. But it does not light the particular LED.
#include "xgpio.h"
#include "xutil.h"
int main (void)
   XGpio led,Push;
   int push_check1, push_check=0;
   xil_printf("-- Entering main() --\r\n");
   XGpio_Initialize(&led,XPAR_LEDS_4BIT_DEVICE_ID);
   XGpio_Initialize(&Push,XPAR_PUSH_BUTTONS_5BIT_DEVICE_ID);
   XGpio_SetDataDirection(&led,1,0x0);
   XGpio_SetDataDirection(&Push,1,0xffffffff);
   xil_printf("Press center push button to exit\r\n");
   xil_printf("Any other to see corresponding LED turn ON\r\n");
   push_check = XGpio_DiscreteRead(&Push,1);
   while(1)
      push_check1 = XGpio_DiscreteRead(&Push,1);
      if(push_check1 != push_check)
        push_check=push_check1;
        if(push_check)
        xil_printf("Push buttons status %0x\r\n", push_check1);
    if(push_check==0x10)
       break;
    XGpio_DiscreteWrite(&led,1,push_check); // Should light up the LED. But it does not.
   xil_printf("-- Exiting main() --\r\n");
   return 0;
Below is the  UCF that was generated by the XPS 9.2 for virtex4 (ML401) board
#### Module LEDs_4Bit constraints
Net fpga_0_LEDs_4Bit_GPIO_IO_pin<0> LOC=G5;
Net fpga_0_LEDs_4Bit_GPIO_IO_pin<0> IOSTANDARD = LVCMOS25;
Net fpga_0_LEDs_4Bit_GPIO_IO_pin<0> PULLUP;
Net fpga_0_LEDs_4Bit_GPIO_IO_pin<0> SLEW = SLOW;
Net fpga_0_LEDs_4Bit_GPIO_IO_pin<0> DRIVE = 2;
Net fpga_0_LEDs_4Bit_GPIO_IO_pin<0> TIG;
Net fpga_0_LEDs_4Bit_GPIO_IO_pin<1> LOC=G6;
Net fpga_0_LEDs_4Bit_GPIO_IO_pin<1> IOSTANDARD = LVCMOS25;
Net fpga_0_LEDs_4Bit_GPIO_IO_pin<1> PULLUP;
Net fpga_0_LEDs_4Bit_GPIO_IO_pin<1> SLEW = SLOW;
Net fpga_0_LEDs_4Bit_GPIO_IO_pin<1> DRIVE = 2;
Net fpga_0_LEDs_4Bit_GPIO_IO_pin<1> TIG;
Net fpga_0_LEDs_4Bit_GPIO_IO_pin<2> LOC=A11;
Net fpga_0_LEDs_4Bit_GPIO_IO_pin<2> IOSTANDARD = LVCMOS25;
Net fpga_0_LEDs_4Bit_GPIO_IO_pin<2> PULLUP;
Net fpga_0_LEDs_4Bit_GPIO_IO_pin<2> SLEW = SLOW;
Net fpga_0_LEDs_4Bit_GPIO_IO_pin<2> DRIVE = 2;
Net fpga_0_LEDs_4Bit_GPIO_IO_pin<2> TIG;
Net fpga_0_LEDs_4Bit_GPIO_IO_pin<3> LOC=A12;
Net fpga_0_LEDs_4Bit_GPIO_IO_pin<3> IOSTANDARD = LVCMOS25;
Net fpga_0_LEDs_4Bit_GPIO_IO_pin<3> PULLUP;
Net fpga_0_LEDs_4Bit_GPIO_IO_pin<3> SLEW = SLOW;
Net fpga_0_LEDs_4Bit_GPIO_IO_pin<3> DRIVE = 2;
Net fpga_0_LEDs_4Bit_GPIO_IO_pin<3> TIG;
#### Module Push_Buttons_5Bit constraints
Net Push_Buttons_5Bit_GPIO_in_pin<0> LOC=B6;
Net Push_Buttons_5Bit_GPIO_in_pin<0> IOSTANDARD = LVCMOS25;
Net Push_Buttons_5Bit_GPIO_in_pin<0> PULLUP;
Net Push_Buttons_5Bit_GPIO_in_pin<0> SLEW = SLOW;
Net Push_Buttons_5Bit_GPIO_in_pin<0> DRIVE = 2;
Net Push_Buttons_5Bit_GPIO_in_pin<0> TIG;
Net Push_Buttons_5Bit_GPIO_in_pin<1> LOC=E9;
Net Push_Buttons_5Bit_GPIO_in_pin<1> IOSTANDARD = LVCMOS25;
Net Push_Buttons_5Bit_GPIO_in_pin<1> PULLUP;
Net Push_Buttons_5Bit_GPIO_in_pin<1> SLEW = SLOW;
Net Push_Buttons_5Bit_GPIO_in_pin<1> DRIVE = 2;
Net Push_Buttons_5Bit_GPIO_in_pin<1> TIG;
Net Push_Buttons_5Bit_GPIO_in_pin<2> LOC=A6;
Net Push_Buttons_5Bit_GPIO_in_pin<2> IOSTANDARD = LVCMOS25;
Net Push_Buttons_5Bit_GPIO_in_pin<2> PULLUP;
Net Push_Buttons_5Bit_GPIO_in_pin<2> SLEW = SLOW;
Net Push_Buttons_5Bit_GPIO_in_pin<2> DRIVE = 2;
Net Push_Buttons_5Bit_GPIO_in_pin<2> TIG;
Net Push_Buttons_5Bit_GPIO_in_pin<3> LOC=F10;
Net Push_Buttons_5Bit_GPIO_in_pin<3> IOSTANDARD = LVCMOS25;
Net Push_Buttons_5Bit_GPIO_in_pin<3> PULLUP;
Net Push_Buttons_5Bit_GPIO_in_pin<3> SLEW = SLOW;
Net Push_Buttons_5Bit_GPIO_in_pin<3> DRIVE = 2;
Net Push_Buttons_5Bit_GPIO_in_pin<3> TIG;
Net Push_Buttons_5Bit_GPIO_in_pin<4> LOC=E7;
Net Push_Buttons_5Bit_GPIO_in_pin<4> IOSTANDARD = LVCMOS25;
Net Push_Buttons_5Bit_GPIO_in_pin<4> PULLUP;
Net Push_Buttons_5Bit_GPIO_in_pin<4> SLEW = SLOW;
Net Push_Buttons_5Bit_GPIO_in_pin<4> DRIVE = 2;
Net Push_Buttons_5Bit_GPIO_in_pin<4> TIG;
 What should I do to rectify this problem, in such when I push the button , the particular LED should light up ?
Thank you
Re: LED Problem( When Press Push Button, no LED light up)
i think your failure is here:
Here you declare the Direction of the LED-Port as INput. You have to insert 0x0000 instead of 0xffffffff.
Greetings
M.Rapp
Sorry. Forget it. I looked false
Good morning,
I know for printf is xil_printf , but what is for scanf?
Thank you
