LWIP in UDP
Hi Everybody,
      I want to send data from Zedboard to PC via Ethernet, for this I am using LWIP in UDP protocol only.
  Echo function is working in UDP protocol. But now I want to send my own data ( single integer), to do this what changes is required in following code.The Echo function code attached, please find it and do help to me.
void udp_echo_recv(void *arg, struct udp_pcb *pcb, struct pbuf *p, struct
ip_addr *addr, u16_t port)
if (p != NULL) {
/* send received packet back to sender */
udp_sendto(pcb, p, addr, port);
/* free the pbuf */
pbuf_free(p);
Re: LWIP in UDP
Hi narendrandesainath@gmail.com ,
Please change the variable P in udp_sendto() function with interger value. basically in the data that is recevied in recv handler will be sent back using udp_sendto() function and the received data stored in variable P. if you replace the variable P with your interger value then this function will send the integer data to PC when PC requested any packet.
Best Regards,
Srikanth
