Visitor parampampam
Linux freezes when it writes to physical memory (Zynq-7000, ArchLinux)
Hello, everyone.
I want to turn on LEDs on my ZedBoard using a Linux application, but my app freezes when it try to write to a physical memory. This is my code:
int main(int argc, char *argv[])
	unsigned int devAddr = 0x41200000;
	unsigned int pageSize = sysconf(_SC_PAGESIZE);
	unsigned int pageAddr = (devAddr & (~(pageSize - 1)));
	unsigned int pageOffset = devAddr - pageAddr;
	int fd = open("/dev/mem", O_RDWR);
	void* ptr = mmap(NULL, pageSize, PROT_READ | PROT_WRITE, MAP_PRIVATE, fd, pageAddr);
	if (ptr == NULL)
		printf("Can't map memory\n");
		return -1;
	unsigned int* devPtr = (unsigned int*)(ptr + pageOffset);
	devPtr[0] = 0xAAAAAAAA;
	devPtr[2] = 0xAAAAAAAA;
	munmap(ptr, pageSize);
	return 0;
 It halts on "devPtr[0] = 0xAAAAAAAA".
I performed following steps:
1. Ran ArchLinux on ZedBoard
2. Wrote bitstream via JTAG
3. Ran my application
Also I tried to write to the memory via U-Boot (mw.l 0x41200000 0xAAAAAAAA), but I had the same result.
You can see a structure of my system on the attached screenshots.
Thanks in advance.
Visitor parampampam
Re: Linux freezes when it writes to physical memory (Zynq-7000, ArchLinux)
The problem is solved. I used cat bitsstream.bit > /dev/xdevcfg on PS instead of writing my bitstream by JTAG. It works on ArchLinux. Thanks for your replies.
mem_fd = open("/dev/mem", O_RDWR|O_SYNC);
if (mem_fd < -1)
    printf("TestApp: Error opening mem_fd for writing.\n");
    return -1;
uint32_t* gpio_addr = (uint32_t*)mmap(0, 64*1024, PROT_READ|PROT_WRITE, MAP_SHARED, mem_fd, 0x41200000);
if (gpio_addr == 0)
    printf("TestApp: mmap() failed.\n");
    return -2;
*(volatile uint32_t*)(gpio_addr + 0) = 0x01;
Most likely it's your hardware desing. Hard to say what exactly - your block diagram looks fine to me. But it could be a problem with a clock settings or your custom module.
Also, code above works for me.
Scholar norman_wong
If it was u-boot fail and linux works, it would be translation table setting in the FSBL. In your case, it might be what user "vanmierlo" found in this thread:
http://forums.xilinx.com/t5/Embedded-Linux/Zynq-Bus-Error-on-mmap-ed-io/td-p/354271
User "vanmierlo" found that it is not allowed to use two different clocks on both sides of the BRAM. He changed them both to use FCLK_CLK0 and got it to work.
Visitor parampampam
I tried the code of fanat9, but got the same result.
At first I tried a default Vivado design for ZedBoard without any custom IPs and external clocks. I had the same freeze in the app.
Can this problem be connected with writing the bitstream when the linux is running? I can't write the bitstream and reboot the linux because the first stage bootloader rewrites my bitstream.
Visitor parampampam
I tried to use a Linux from SD-card supplied with ZedBoard. I got "segmentation fault" with default bitstream. Then I attempted to write my bitstream by JTAG. The linux rebooted and the FSBL rewrote my bitstream by a default one. Is there any way to test my bitstream without rewriting QSPI Flash?
Visitor parampampam
Participant bpb
@parampampam the real problem is that you're using MAP_PRIVATE. Try MAP_SHARED instead.
