Local memory (BRAM) size limitations for Micorblaze
Hi All,
I want to have a local memory of 256 KB for the microblaze. From various sources, I read that the LMB BRAM Interface Controller can not have. For example, here it is mentioned that the LMB BTAM Interface Controller can support up to 128 KB.
Additionally, PG 116 states that "The size of the local memory is parameterized and can be between 4 kB and 128 kB."
So, I am confused because of above conflicting information about local memory size. Can I have a local memory that is larger than 128 KB? If so, could you please let me how can I have a local memory for the microblaze that is equal to 256 KB ? Using DDR is no option for me.
Thanks all
Re: Local memory (BRAM) size limitations for Micorblaze
You can increase the size in the address editor. There is a limitation of the BRAM size in the block automation to 128Kb. This is due to fact that you might see timing issues with the address strobe on larger memories. However, you should be fine with 256KB
