LogiCVC v5.0 error when increase the number of layers.
Hi Xilinx/Xylon?
I am using TRD 2015.4 and doing some modifications by adding an external video source.
I am trying to increase the number of layers to 5, but during synthesis the following error came out.
Previously I tried to increase layers to to 4, "array index 3 out of range" was the error.
Since the RTL is encrypted, what can I do now?
Thank you.
[Synth 8-97] array index 4 out of range ["d:/zc706/trd_154/lc_v2/leica_cam/leica_cam.srcs/sources_1/bd/zc702_base_trd/ipshared/logicbricks.com/logicvc_v5_0/hdl/src/vhdl/video_fifo.vhd":39]
[Synth 8-285] failed synthesizing module 'video_fifo' ["d:/zc706/trd_154/lc_v2/leica_cam/leica_cam.srcs/sources_1/bd/zc702_base_trd/ipshared/logicbricks.com/logicvc_v5_0/hdl/src/vhdl/video_fifo.vhd":39]
[Synth 8-285] failed synthesizing module 'scramble' ["d:/zc706/trd_154/lc_v2/leica_cam/leica_cam.srcs/sources_1/bd/zc702_base_trd/ipshared/logicbricks.com/logicvc_v5_0/hdl/src/vhdl/scramble.vhd":39]
[Synth 8-285] failed synthesizing module 'logicvc' ["d:/zc706/trd_154/lc_v2/leica_cam/leica_cam.srcs/sources_1/bd/zc702_base_trd/ipshared/logicbricks.com/logicvc_v5_0/hdl/src/vhdl/logicvc.vhd":39]
[Synth 8-285] failed synthesizing module 'zc702_base_trd_logicvc_1_0' ["d:/zc706/trd_154/lc_v2/leica_cam/leica_cam.srcs/sources_1/bd/zc702_base_trd/ip/zc702_base_trd_logicvc_1_0/synth/zc702_base_trd_logicvc_1_0.vhd":139]
[Synth 8-285] failed synthesizing module 'hdmi_output_imp_1MU3ZBV' ["D:/zc706/trd_154/lc_v2/leica_cam/leica_cam.srcs/sources_1/bd/zc702_base_trd/hdl/zc702_base_trd.vhd":461]
[Synth 8-285] failed synthesizing module 'zc702_base_trd' ["D:/zc706/trd_154/lc_v2/leica_cam/leica_cam.srcs/sources_1/bd/zc702_base_trd/hdl/zc702_base_trd.vhd":11879]
[Synth 8-285] failed synthesizing module 'zc702_base_trd_wrapper' ["D:/zc706/trd_154/lc_v2/leica_cam/leica_cam.srcs/sources_1/bd/zc702_base_trd/hdl/zc702_base_trd_wrapper.vhd":53]
[Common 17-69] Command failed: Synthesis failed - please see the console or run log file for details
回复: LogiCVC v5.0 error when increase the number of layers.
Second question, my new video source will be from camera sensor and I am not using the HDMII interface so I can easily tie my camera to the layer 2. However FW crashes when I change video source to HDMII since FW seems to get the HDMII video timing/resolution from somewhere. I only managed to disable the resolution check in vlib_change_mode.
Where can I look into the codes to get arround it? I am new to linux and don't wish to get into the kernel.
Observer xylonsupport
Hi, lis_user1
Could you give us more details of configuration of logiCVC from Vivado?
Cheers,
Xylon Support
