Newbie xdwumin
MapLib 979 978 error when create microblaze instance
After I create a Microblaze MCS in project navigator 13.4.
The map is faild, error is:
NGDBUILD done.Process "Translate" completed successfully
Started : "Map".
Running map...
Command Line: map -intstyle ise -p xc4vlx40-ff668-10 -global_opt off -cm area -ir off -pr off -c 100 -o top_map.ncd top.ngd top.pcf
Using target part "4vlx40ff668-10".
Mapping design into LUTs...
ERROR:MapLib:979 - LUT4 symbol
   "vor/vor_mcs/U0/iomodule_0/IOModule_Core_I1/Using_UART_RX.UART_RX_I1/RX_Frame_Error1" (output
   signal=vor/vor_mcs/U0/iomodule_0/IOModule_Core_I1/rx_frame_error) has input
   signal
   "vor/vor_mcs/U0/iomodule_0/IOModule_Core_I1/Using_UART_RX.UART_RX_I1/new_rx_d
   ata<0>" which will be trimmed. See Section 5 of the Map Report File for
   details about why the input signal will become undriven.
   "vor/vor_mcs/U0/iomodule_0/IOModule_Core_I1/Using_UART_RX.UART_RX_I1/new_rx_data_write_and00001" (output
   signal=vor/vor_mcs/U0/iomodule_0/IOModule_Core_I1/Using_UART_RX.UART_RX_I1/ne
   w_rx_data_write_and0000) has input signal
   "vor/vor_mcs/U0/iomodule_0/IOModule_Core_I1/Using_UART_RX.UART_RX_I1/serial_to_parallel<1>1" (output
   signal=vor/vor_mcs/U0/iomodule_0/IOModule_Core_I1/Using_UART_RX.UART_RX_I1/se
   rial_to_parallel<1>) has input signal
ERROR:MapLib:979 - LUT3 symbol
   "vor/vor_mcs/U0/iomodule_0/IOModule_Core_I1/Using_UART_RX.UART_RX_I1/start_Edge_Detected_0_and00001" (output
   signal=vor/vor_mcs/U0/iomodule_0/IOModule_Core_I1/Using_UART_RX.UART_RX_I1/st
   art_Edge_Detected_0_and0000) has input signal
   "vor/vor_mcs/U0/iomodule_0/IOModule_Core_I1/Using_UART_RX.UART_RX_I1/previous
   _RX" which will be trimmed. See Section 5 of the Map Report File for details
ERROR:MapLib:979 - LUT2 symbol
   "vor/vor_mcs/U0/iomodule_0/IOModule_Core_I1/Using_UART_TX.UART_TX_I1/tx_buffer_empty_i_or00001" (output
   signal=vor/vor_mcs/U0/iomodule_0/IOModule_Core_I1/Using_UART_TX.UART_TX_I1/tx
   _buffer_empty_i_or0000) has input signal "vor/vor_mcs/U0/LMB_Rst" which will
   be trimmed. See Section 5 of the Map Report File for details about why the
ERROR:MapLib:978 - LUT4 symbol
   signal=vor/vor_mcs/U0/iomodule_0/IOModule_Core_I1/rx_frame_error) has an
   equation that uses input pin I1, which no longer has a connected signal.
   Please ensure that all the pins used in the equation for this LUT have
   signals that are not trimmed (see Section 5 of the Map Report File for
   details on which signals were trimmed).
   w_rx_data_write_and0000) has an equation that uses input pin I1, which no
   longer has a connected signal. Please ensure that all the pins used in the
   equation for this LUT have signals that are not trimmed (see Section 5 of the
   Map Report File for details on which signals were trimmed).
   rial_to_parallel<1>) has an equation that uses input pin I2, which no longer
   has a connected signal. Please ensure that all the pins used in the equation
   for this LUT have signals that are not trimmed (see Section 5 of the Map
ERROR:MapLib:978 - LUT3 symbol
   art_Edge_Detected_0_and0000) has an equation that uses input pin I0, which no
   art_Edge_Detected_0_and0000) has an equation that uses input pin I1, which no
ERROR:MapLib:978 - LUT2 symbol
   _buffer_empty_i_or0000) has an equation that uses input pin I0, which no
Error found in mapping process, exiting...
Errors found during the mapping phase.  Please see map report file for more
details.  Output files will not be written.
Design Summary
Number of errors   :  12
Number of warnings :   0
Process "Map" failed
I only add a fixed timer and Uart in MCS, the module like this:
component mb_mcs is
  port (
    Clk : in STD_LOGIC := 'X';
    Reset : in STD_LOGIC := 'X';
    FIT1_Toggle : out STD_LOGIC;
    UART_Rx : in STD_LOGIC := 'X';
    UART_Tx : out STD_LOGIC
end component;
the instance is:
vor_mcs	:	mb_mcs
port map (
    Clk 						=>	clk50M,
    Reset 		=>	open,
    FIT1_Toggle 		=>	open,
    UART_Rx 		=>	open,
    UART_Tx			=>	mcs_uart_tx);
where clk50M is a 50MHz clock from top level module, and mcs_uart_tx is connected to an output bin in top level.
Any one know how to solve it?
