Merging a MicroBlaze and a Image Processing IP Block
I need some tips do implement a project: I need to connect a MicroBlaze processor to a Convolution IP Block that i've just implemented using HLS. There must be a Image stored in MicroBlaze and that image must be transfered to the IP Block, be processed and return to the MicroBlaze.
Whats is the best way to do this? It's a single image that a need to send.
For now, that is the blocks I have:
The Conv HLS code is the following:
#include "conv.h"
void conv(uint8_t image_in[rows*collums],uint8_t image_out[rows*collums]){
	#pragma HLS INTERFACE m_axi depth=1440000 port=image_out offset=slave bundle=CRTL_BUS
	#pragma HLS INTERFACE m_axi depth=1440000 port=image_in offset=slave bundle=CRTL_BUS
	#pragma HLS DATAFLOW
	#pragma HLS INTERFACE s_axilite port=return bundle=lite
   const char coefficients[3][3] = { {-1,-2,-1},
                                     { 0, 0, 0},
                                     { 1, 2, 1} };
   hls::Mat<collums,rows,HLS_8UC1> src;
   hls::Mat<collums,rows,HLS_8UC1> dst;
   hls::AXIM2Mat<rows,uint8_t,collums,rows,HLS_8UC1>(image_in,src);
   hls::Window<3,3,char> kernel;
   for (int i=0;i<3;i++){
      for (int j=0;j<3;j++){
         kernel.val[i][j]=coefficients[i][j];
   hls::Point_<int> anchor = hls::Point_<int>(-1,-1);
   hls::Filter2D(src,dst,kernel,anchor);
   hls::Mat2AXIM<rows,uint8_t,collums,rows,HLS_8UC1>(dst,image_out);
Scholar hbucher
Re: Merging a MicroBlaze and a Image Processing IP Block
 @tiago0297 Create a block with BRAM or DDR. It will expose a slave port.
Then connect both MicroBlaze and Conv's master ports to it through an AXI interconnect. Connection automation should take care of this for you.
You also need to make s_axi_lite a slave of the Microblaze so you can start/stop/configure your block.
The image will be stored in the BRAM? How it's done?
When I do this, the MicroBlaze will be able to get it from the BRAM and send it to the Conv, then Conv will send it back to the BRAM?
Scholar hbucher
@tiago0297 The way you set up, you have an AXI master. It will issue AXI read and then write commands to the interconnect and fetch the data for you. This is already done by HLS in your block.
Microblaze only has to configure the IP's slave offset and start the IP block using the SDK-provided API.
Nice, I think I understood. But I still have some questions, i'm new to Vivado.
So the MicroBlaze will be in charge to get the image from the BRAM and send it to Conv. But my Image is a .jpeg file and I don't understood how can I load this file in the BRAM. How can I do this?
Scholar hbucher
Microblaze will just fetch this image and decompress it in memory. Not sure if opencv is available for microblaze but if it does you can use cvloadimage. Otherwise I remember tinydnn comes with a header only jpeg/png reader.
You can alternatively use "convert" on Linux to generate a raw file and then upload to Bram using XSCT
I"m still confused about how I can initialize my memory with my image. What's the best way to do this?
I've connected the MicroBlaze, the Conv IP Block and a BRAM. I'm attaching the pdf of my design. Now, I want to initialize my memory with a Image I have stored in my computer, then send this image to the Conv and get it back to the memory. Am I on the right way to do this?
I've tryied to use the Memory Configuration File Generator on Tools of the Vivado, selecting my image and asking it to generate a file for me. I'm a very beginner user, so I really don't know if it's the best way to generate a initialization file for my BRAM. Unfortunately, this didn't work for me because of the following error: [Writecfgmem 68-4] Bitstream at address 0x00000000 has size 385828 bytes which cannot fit in memory of size 2097152 bytes.
