MicroBlaze PVR Register
I would like to use a register within a MicroBlaze as a special data anchor address that is loaded and used at run-time.   The PVR registers seemed useful at first, but their values are static.  Is there another type of register that can be used for this purpose that the compiler won't clobber?  Any help will be greatly appreciated.
Re: MicroBlaze PVR Register
I like jraph's suggestion. Each MicroBlaze would have a different PVR (static) which would be used to read a unique address in the shared peripheral map with the dynamic value of the associated peripheral register entry. The code for the processors could even be the same.
bt
Why does it have to be inside Microblaze?
Can't normal data in memory work?
Göran
Visitor jralph
Would a  PLB/OPB addressible flip-flop register work? Then you just access a 32 bit address in processor memory to read / write the register and contained bit-fields.
For handeling many different registers http://SpectaReg.com provides automation of logic/firmware and more.  It supports XPS MicroBlaze systems.
The system contains multiple MicroBlazes and each needs to have a unique identifier that can be changed during run-time.  Currently all of the processors are on a shared bus, so a single memory-mapped register will give them all the same ID.  I could segment the system to use different busses, and then put a ID register on each bus at the same address with different values, but this is a very heavyweight solution.
-Jason
Visitor jralph
Could you have a different memory-mapped register for each MicroBlaze and still share the same bus?  Then each MicroBlaze would read a different address.
bt
That's a good idea.  I can easily create a single slave core using CreateIP and I can use the PVR register as an index into this slave core's memory-map.
Thank you,
-Jason
