Observer ccthx1138
MicroBlaze for Spartan-6 in vivado... legacy version required?
Hi all.  So I am considering Spartan-6 for a new design, as Spartan-6 is supported by AD10 design platform, but I have read that a 'legacy' version of Vivado is required to use MicroBlaze processor on Spartan-6.  Is this true?
If so, is this version still available?, and what is it called?
Just how 'legacy' is it - will the latest Vivado be a much better starting point for entrance into the Xilinx development system?
Finally, I'm just diving into Vivado, and every bit of help, streamlining, and higher level of abstraction is going to help me get up to speed - how does the legacy Vivado compare to the latest in this regard?  Thanks for your comments and suggestions.
Cheers,
Bob
Scholar hbucher
Re: MicroBlaze for Spartan-6 in vivado... legacy version required?
@ccthx1138
It is called ISE Design Suite. I loved it - when I used it. It's been a few years.
https://www.xilinx.com/products/design-tools/ise-design-suite.html
It is a very good tool.
In my opinion - yes, hands down.  Although it depends on what you are doing.
Vivado is more modern. It supports all the new devices and it is integrated with Vivado SDK, Vivado HLS, SDSoC, SDx.
But you'd have to use ISE for CLPDs and older devices like Spartan-6. Spartan-7 are supported by Vivado though.
ISE is still actively supported. The latest version for Windows 10 was last updated December 2017 but that's just bug updates, no enhancements (I believe). This is the same version (14.7) released in October 2013, four years ago.
https://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/design-tools/v2012_4---14_7.html
There is no competition. If you want to code for Xilinx devices, which are currently the top/best in the market, you have to use Vivado.
Scholar u4223374
With the Spartan 6 you can't use Vivado at all; no version of Vivado supports anything earlier than the 7-series.
Instead you'd be limited to ISE, which is pretty old and doesn't tend to play well with modern operating systems (Xilinx's advice for running ISE on Windows 10 is basically "install a Linux virtual machine and run ISE on that"). ISE also tends to make you pay for a lot of things that are free in Vivado - I have a suspicion that Microblaze is one of these.
For a new design, I would not consider a Spartan 6. Spartan 7 or Zynq 7000 is the way to go. Spartan 7 is a fairly close equivalent to the Spartan 6, Zynq 7000 gives you a fast ARM CPU that might eliminate your need for MicroBlaze. Either will work in the latest version of Vivado.
Scholar hbucher
@ccthx1138
