MicroBlaze - multiple callback references for interrupt?
I have a timer running using interrupts in a microblaze design.  I noticed in Xilinx examples the call back reference passed is usually the timer instance.  I'm doing this as well.  Is there a way to pass more data, another structure pointer or void function pointer in addition to the default CallBackRef?  I'm wondering if I can pass more information to the timer interrupt handler.
Here is my binding for the timer interrupt:
	status = XIntc_Connect(ptrXintc, XPAR_INTC_0_TMRCTR_0_VEC_ID,
							(XInterruptHandler)TimerCounterHandler, (void*)ptrXtmrCtr0);
The ptrXtmrCtr0 consists of the following:
#include <stdio.h>
#include "platform.h"
#include "xil_printf.h"
#include "xgpio.h"
#include "xintc.h"
#include "xtmrctr.h"
#include "xspi.h"
u32 peripheral_init();
XGpio* ptrGPIO_LED;
XIntc* ptrXintc;
XTmrCtr* ptrXtmrCtr0;
XSpi* ptrXSpi0;
XSpi_Config* Spi0_cfg;
int main()
    init_platform();
	XGpio GPIO_LED;
	XIntc intc;
	XTmrCtr XTmrCtr0;
	XSpi XSpi0;
	ptrGPIO_LED = &GPIO_LED;
	ptrXintc = &intc;
	ptrXtmrCtr0 = &XTmrCtr0;
	ptrXSpi0 = &XSpi0;
    peripheral_init();
    xil_printf("-Peripherals Configured!\n");
	microblaze_enable_interrupts();
	xil_printf("-Interrupts Enabled!\n");
    XTmrCtr_Start(ptrXtmrCtr0, XPAR_AXI_TIMER_0_DEVICE_ID);
    xil_printf("-Timer Started!\n");
    while(1);
    cleanup_platform();
    return 0;
Basically I'm wondering if I can pass more information to an interrupt service routine than just the call back reference that consists of a pointer to the peripheral instance.  If I can't pass information to a service routine via the callback it seems as though I have to make the information I want to the interrupt routine to see global.  Is that a bad thing? To make stuff (data structures etc...) global so an ISR can see it?
Scholar hbucher
Re: MicroBlaze - multiple callback references for interrupt?
@m3atwad You can pass any pointer you want. Make a struct with whatever you wish inside and pass a pointer to it then cast it back in the ISR.
Scholar hbucher
Ok cool.  Just wanted to check because it seemed too simple to be a legit solution.
Thanks!
Scholar hbucher
@m3atwad
It is a very common pattern in C
