Microblaze GPIO Interrupt with accelemeter sensor (Neso Artix-7)
I am using GPIO interrupt with interrupt source from INT in LIS331HH accelemeter sensor. I use the xgpio_intr_tapp_example in library of sdk for gpio. But the problem is this code not work. The program initialize the sensor is work but the GPIO_Intr1() function don't work.
This is the first post for me , I'm newbie and I hope finding helpful replys
thanks!
this is my code:
#include "xparameters.h"    /* XPAR parameters */
#include "xspi.h"        /* SPI device driver */
#include "xspi_l.h"
#include "xil_printf.h"
#include "xil_exception.h"
#include "math.h"
#include <stdio.h>
#include "xgpio.h"
//#ifdef XPAR_INTC_0_DEVICE_ID
 #include "xintc.h"
 #include <stdio.h>
//#else
// #include "xscugic.h"
// #include "xil_printf.h"
//#endif
//#include "LIS331HH.h"
//#include "xintc.h"        /* Interrupt controller device driver */
/************************** Constant Definitions *****************************/
#define SPI_DEVICE_ID        XPAR_SPI_0_DEVICE_ID
#define GPIO_DEVICE_ID        XPAR_GPIO_2_DEVICE_ID
#define INTC_DEVICE_ID        XPAR_INTC_0_DEVICE_ID
 #define INTC            XIntc
 #define INTC_HANDLER    XIntc_InterruptHandler
//#else
// #define INTC_DEVICE_ID    XPAR_SCUGIC_SINGLE_DEVICE_ID
// #define INTC            XScuGic
// #define INTC_HANDLER    XScuGic_InterruptHandler
//#endif
 *  This is the size of the buffer to be transmitted/received in this example.
#define BUFFER_SIZE            22
#define DATA_BUFFER_SIZE    12
#define DATA_LEGTH            16
 *  Proxy register address
#define TINT 0x1
#define GFK  0x1
#define GFID 0x1
#define COMMAND_BYTE_1_OFFSET 0
#define COMMAND_BYTE_2_OFFSET 1
#define COMMAND_BYTE_3_OFFSET 2
#define COMMAND_BYTE_4_OFFSET 3
#define COMMAND_BYTE_5_OFFSET 4
#define COMMAND_BYTE_6_OFFSET 5
#define COMMAND_BYTE_7_OFFSET 6
#define COMMAND_BYTE_8_OFFSET 7
#define COMMAND_BYTE_9_OFFSET 8
#define COMMAND_BYTE_10_OFFSET 9
#define SCALE 0.0007324; // approximate scale factor for full range (+/-24g)
// scale factor: +/-24g = 48G range. 2^16 bits. 48/65536 = 0.0007324
// global acceleration values
double xAcc, yAcc, zAcc;
double roll, pitch, roll_raw, pitch_raw;
int xVal, yVal, zVal, xL, xH, yL, yH, zL, zH;
double Angle[3][2] =
    { 0, 0},  //row 1
    { 0, 0}, //row 2
    { 0, 0}  //row 3
double Angle_filter[3][2] =
    { 0, 0},  //row 1
    { 0, 0},  //row 2
    { 0, 0}   //row 3
int m = 1;
int d = 0;
//for (i = 0; i < 3; i++)
//    for(j = 0; j < 2; j++)
//        Angle[i][j]        = 0;
//        Angle_filter[i][j] = 0;
//#define SPI_DEVICE_ID        XPAR_SPI_0_DEVICE_ID
//#define INTC_DEVICE_ID        XPAR_INTC_0_DEVICE_ID
//#define SPI_INTR_ID        XPAR_INTC_0_SPI_0_VEC_ID
/**************************** Type Definitions *******************************/
 * The following data type is used to send and receive data on the SPI
 * interface.
typedef u8 DataBuffer[BUFFER_SIZE];
/************************** Function Prototypes ******************************/
int SpiMasterExample(    XSpi *SpiInstancePtr,
                        u16 SpiDeviceId);
//static int SetupInterruptSystem(XSpi *SpiPtr);
void SpiHandler(    void *CallBackRef,
                    u32 StatusEvent,
                    unsigned int ByteCount);
void Measure_angle();
int GPIO_Intr1(    INTC *IntcInstancePtr,
                XGpio *InstancePtr,
                u16 DeviceId,
                u16 IntrId,
                u16 IntrMask);
int GpioSetupIntrSystem(INTC *IntcInstancePtr,
                        XGpio *InstancePtr,
                        u16 DeviceId,
                        u16 IntrId,
                        u16 IntrMask);
void GpioDisableIntr(INTC *IntcInstancePtr,
                    XGpio *InstancePtr,
                    u16 IntrId,
                    u16 IntrMask);
void GpioHandler();
/************************** Variable Definitions *****************************/
 * The instances to support the device drivers are global such that the
 * are initialized to zero each time the program runs.
static XSpi  SpiInstance;     /* The instance of the SPI device */
XGpio Gpio; /* The Instance of the GPIO Driver */
INTC Intc; /* The Instance of the Interrupt Controller Driver */
static u16 GlobalIntrMask;
static volatile u32 IntrFlag; /* Interrupt Handler Flag */
 * The following variables are used to read and write to the  Spi device, they
 * are global to avoid having large buffers on the stack.
//u8 ReadBuffer[BUFFER_SIZE];
u8 WriteBuffer[BUFFER_SIZE];
u8 ReadBuffer[DATA_BUFFER_SIZE];
int main(void){
    int Status;
//    double roll, pitch;
     * Run the Spi Polled example.
    Status = SpiMasterExample(&SpiInstance, SPI_DEVICE_ID);
    if (Status != XST_SUCCESS) {
        xil_printf("Spi polled Example Failed\r\n");
        return XST_FAILURE;
    // GPIO Interrupt on INT1_port in LIS331HH:
    Status = GPIO_Intr1(&Intc,
                        &Gpio,
                             GPIO_DEVICE_ID,
                       XPAR_INTC_0_GPIO_2_VEC_ID,
                       XPAR_AXI_GPIO_2_IP2INTC_IRPT_MASK);
    while(1)
    return XST_SUCCESS;
* This function does a minimal test on the Spi device and driver as a
* design example. The purpose of this function is to illustrate how to use
* the XSpi component using the polled mode.
* This function sends data and expects to receive the same data.
* @param    SpiInstancePtr is a pointer to the instance of Spi component.
* @param    SpiDeviceId is the Device ID of the Spi Device and is the
*        XPAR_<SPI_instance>_DEVICE_ID value from xparameters.h.
* @return    XST_SUCCESS if successful, otherwise XST_FAILURE.
* @note
* This function contains an infinite loop such that if the Spi device is not
* working it may never return.
int SpiMasterExample(XSpi *SpiInstancePtr, u16 SpiDeviceId)
    int Status;
    //u32 Count;
//    u32 Test1, Test2, Test3, Test4, Test5, Test6;
    XSpi_Config *ConfigPtr;    /* Pointer to Configuration data */
     * Initialize the SPI driver so that it is  ready to use.
    ConfigPtr = XSpi_LookupConfig(SpiDeviceId);
    if (ConfigPtr == NULL) {
        return XST_DEVICE_NOT_FOUND;
    Status = XSpi_CfgInitialize(SpiInstancePtr, ConfigPtr,
                  ConfigPtr->BaseAddress);
        return XST_FAILURE;
    * Set the SPI device as a master and in manual slave select mode such
    * that the slave select signal does not toggle for every byte of a
    * transfer, this must be done before the slave select is set.
    Status = XSpi_SetOptions(&SpiInstance, XSP_MASTER_OPTION
                                            | XSP_CLK_ACTIVE_LOW_OPTION
                                            | XSP_CLK_PHASE_1_OPTION);
    if(Status != XST_SUCCESS) {
        return XST_FAILURE;
     * Start the SPI driver so that the device is enabled.
    XSpi_Start(SpiInstancePtr);
     * Disable Global interrupt
    XSpi_IntrGlobalDisable(SpiInstancePtr);
    u8 WriteBuffer[BUFFER_SIZE] = {0x3F,0x20,0x00,0x21,0x02,0x22,0x30,0x23,0x00,0x24,0x00,0x30,0x00,0x32,0x00,0x33,0x2A,0x34,0x05,0x36,0x00,0x37};
//     * Select the slave on the SPI bus so that the device can be
//     * accessed using the SPI bus.
    Status = XSpi_SetSlaveSelect(&SpiInstance, 0x01);
        return XST_FAILURE;
////     * Transmit the data.
    XSpi_Transfer(SpiInstancePtr, WriteBuffer, NULL, BUFFER_SIZE);
    Status = XSpi_SetSlaveSelect(&SpiInstance, 0x00);
        return XST_FAILURE;
    return XST_SUCCESS;
* Initialize the GPIO driver and setup Interrupt System
* @param    IntcInstancePtr is a reference to the Interrupt Controller
*        driver Instance
* @param    InstancePtr is a reference to the GPIO driver Instance
* @param    DeviceId is the XPAR_<GPIO_instance>_DEVICE_ID value from
*        xparameters.h
* @param    IntrId is XPAR_INTC_0_GPIO_2_VEC_ID
*        value from xparameters.h
* @param    IntrMask is the GPIO channel mask: XPAR_AXI_GPIO_2_IP2INTC_IRPT_MASK in xparameter.h
* @return
*        - XST_SUCCESS if the Test is successful
*        - XST_FAILURE if the test is not successful
* @note        None.
int GPIO_Intr1(    INTC *IntcInstancePtr, XGpio *InstancePtr, u16 DeviceId, u16 IntrId, u16 IntrMask)
    int Status;
    /* Initialize the GPIO driver. If an error occurs then exit */
    Status = XGpio_Initialize(InstancePtr, DeviceId);
            return XST_FAILURE;
    XGpio_SelfTest(&Gpio);
    Status = GpioSetupIntrSystem(IntcInstancePtr, InstancePtr, DeviceId,
                            IntrId, IntrMask);
                return XST_FAILURE;
//    GpioDisableIntr(IntcInstancePtr, InstancePtr, IntrId, IntrMask);
    return Status;
*        driver Instance
*        xparameters.h
* @return
* @note        None.
int GpioSetupIntrSystem(INTC *IntcInstancePtr, XGpio *InstancePtr,    u16 DeviceId, u16 IntrId, u16 IntrMask)
    int Result;
    GlobalIntrMask = IntrMask;
 * Initialize the interrupt controller driver so that it's ready to use.
 * specify the device ID that was generated in xparameters.h
    Result = XIntc_Initialize(IntcInstancePtr, INTC_DEVICE_ID);
    if (Result != XST_SUCCESS) {
        return Result;
/* Hook up interrupt service routine */
    XIntc_Connect(IntcInstancePtr, IntrId, (Xil_ExceptionHandler) GpioHandler, InstancePtr);
/* Enable the interrupt vector at the interrupt controller */
    XIntc_Enable(IntcInstancePtr, IntrId);
 * Start the interrupt controller such that interrupts are recognized
 * and handled by the processor
    Result = XIntc_Start(IntcInstancePtr, XIN_REAL_MODE);
        return Result;
 * Enable the GPIO channel interrupts so that push button can be
 * detected and enable interrupts for the GPIO device
    XGpio_InterruptEnable(InstancePtr, XGPIO_IR_CH1_MASK);
    XGpio_InterruptGlobalEnable(InstancePtr);
 * Initialize the exception table and register the interrupt
 * controller handler with the exception table
    Xil_ExceptionInit();
    Xil_ExceptionRegisterHandler(XIL_EXCEPTION_ID_INT,
             (Xil_ExceptionHandler)INTC_HANDLER, IntcInstancePtr);
/* Enable non-critical exceptions */
    Xil_ExceptionEnable();
    return XST_SUCCESS;
void GpioHandler()
//    XGpio *GpioPtr = (XGpio *)CallbackRef;
    d++;
* This function disables the interrupts for the GPIO
* @param    IntcInstancePtr is a pointer to the Interrupt Controller
*        driver Instance
* @param    InstancePtr is a pointer to the GPIO driver Instance
* @return    None
* @note        None.
void GpioDisableIntr(INTC *IntcInstancePtr, XGpio *InstancePtr,
    XGpio_InterruptDisable(InstancePtr, IntrMask);
    XIntc_Disable(IntcInstancePtr, IntrId);
#else
    /* Disconnect the interrupt */
    XScuGic_Disable(IntcInstancePtr, IntrId);
    XScuGic_Disconnect(IntcInstancePtr, IntrId);
#endif
    return;
