Microblaze Interrupt Port
I created a microblaze in XPS that I instantiate in a large design with ISE. I'd like to send from an AXI Stream Fifo an interrupt to the ublaze saying that it's has reached x packets so the ublaze reads the Fifo.
The problem I have is that I can't find a way to find in XPS the Interrupt port and make it external so I can't link it to y signal from the fifo.
What can I do?
Re: Microblaze Interrupt Port
You need to make an external port for the interrupt similar to the AR below
http://www.xilinx.com/support/answers/56446.html
This is for ARM but the concept is the same for microblaze
