Microblaze Peripheral Constraints
Dear Members;
 I am using SP605 board with Xilinx 12.4. I have a design that has microblaze with various peripherals connected to it, such as SPI.
 I am wondering if the xps automatically generates constraints for these peripherals to function correctly.
For example, after putting a SPI in your XPS design, user defines the clock frequency. Is this timing information automatically added to the constraints list to make sure correct behaviour?
Any help is appreciated,
Best Regards,
Re: Microblaze Peripheral Constraints
Ys but obvious if you create example design using BSB and targetting Boards which are available in the list.
Then the tool will automatically add the default/master ucf containig all the contraint information & sure it works correctly unless you select a custom board you have specify your own constraint information with repect to specific  devices & targetting platform.
