Visitor sabrin
Microblaze and custom IP block
I'm working on zedboard and vivado 2013.4 tool.
I have integrated a Microblaze processor into Programmable logic side (PL),
My goal is to create a custom IP block (hardware accelerator) in the Programmable Logic (PL) portion of the Zynq-7000 device, and connect this custom IP to the Microblaze softcore.
Can you help me please.
Thanks in advance.
Re: Microblaze and custom IP block
This UG1119 has details of creating and packing the custom IP.
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_4/ug1119-vivado-creating-packaging-ip-tutorial.pdf
UG896 has details of using the IP in the project.
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_4/ug896-vivado-ip.pdf
Hope this helps.
Achutha
Scholar sampatd
Some info you will find interesting:
http://www.eetimes.com/document.asp?doc_id=1280680
Also, the following example will be helpful - it is on XPS but the concept can be replicated in Vivado.
http://www.xilinx.com/support/documentation/application_notes/xapp1093-amp-bare-metal-microblaze.pdf
