Microblaze debugging
I'm using ISE 14.2 and SP605 board and there is some troubles with Microbaze debug. When I download simple application in FPGA using "Program" tool - all is OK. But when I start debugging, error "Target reqest failed: Target is not suspended" appears randomly. In one cases there is, in other - not.
Does anyone have a hint?
Thanks so much.
Leofr.
Re: Microblaze debugging
Is it possible to attach the workspace here?
Thank you, I have solved the problem. Now I launch debugging by another way, and it allows to debug with no errors.
