Visitor trenkoff
Microblaze interconnection
I need to connect two Microblaze processors,  each on a seperate Spartan 3e chip, but on the same board. Can this be done through FSL? Would it require two seperate projects in the XPS? Is there an example or tutorial on this subject?
Re: Microblaze interconnection
I have not done something like that before, so my answer might be wrong. As far as I know, you cannot connect them through FSL, or atleast in this case, you need to have interfaces to talk to processors and off-the-FPGA connections. Since your connection is not on-chip, it should not be easy. Again As far I know, you need two projects becuase you are working on two different FPGAs.
