Visitor nemmo0
Modifying AXI_Ethernet example
I have run the examples
xaxiethernet_example_intr_fifo.c
xaxiethernet_example_polled.c
of Vivado 2013.4 on KC705. The polling mode tests and the interrupt mode tests are passed successfully. This example puts the PHY on loopback mode. Now what I want is to break the loopbak and send the packets out to the PC.
How can I modify these example codes to break the loop?
What I did so far is just commented out the line for loopback
//Status = AxiEthernetUtilEnterLoopback(&AxiEthernetInstance, LoopbackSpeed);
Tests fail as expected but cannot observe any packets on wireshark.
Visitor nemmo0
Re: Modifying AXI_Ethernet example
Solved the problem.
AxiEthernetUtilEnterLoopback()  also configures the PHY for speed... etc as well as loopback mode. So left this function but only commented
//XAxiEthernet_PhyWrite(AxiEthernetInstancePtr, PhyAddr, PHY_R0_CTRL_REG, PhyReg0 | PHY_R0_LOOPBACK);
Visitor nemmo0
Solved the problem.
how do you receive packets from pc with application axi_eth_fifo_intr example?
