Visitor dreamerfly
Multiple Ethernet witch Multiple DMA cause a INT error
Hello everyone, I’m trying to add 2 additional Ethernet ports to a custom ZC702 system,my project’s block just like the diagram as below:
and then,
the linux kernel version I used was download from https://github.com/Xilinx/linux-xlnx
the driver is  axienet_emac
but it would report the "DMA Rx error 0x14409" when I startup one eth port alternatively.
I have browsed all related AR#,but can't find a  solution. What should i do?
Tags (3)
Re: Multiple Ethernet witch Multiple DMA cause a INT error
Hi :
I have received similar error on Zynq 7000
net eth1: Current BD is at: 0x2e707940
net eth1: DMA Rx error 0x14409
Looks to be similar to above. Any suggestions/advice on how to fix that ?
CK
Observer gustoff
Hi!
I encountered the same error. Has anyone solved this problem?
With regards,
Gustov Vladimir
