Visitor dosman79
NPI addres
I am trying to make a custom IP which I want to connect via NPI  port, with the MPMC module. I am using EDK 11.4 and board ML506.  Roots of my IP are in example http://www.xilinx.com/support/answers/24912.htm. MPMC is connected to Microblase(plb) and to my IP(NPI). My problem: I wrire the data do DDR2 and I can read this data from Microblaze at addres 0x00000000. But when I change PIM<Port_Num>_Addr for example 0x00001000 the MPMC write the data again on addres 0x00000000. Can anybody direct me, where can be problem, how can I change the starting address?
Tx in advance,
Petr
Re: NPI addres
I can't think what you could be doing wrong here- the NPI Address passess through the MPMC.  It of course has to be aligned to the burst length.
How do you know that the NPI is only writing to 0?  Are you checking with the PLB port?
Perhaps attach your MPMC MHS snippet.
Visitor dosman79
Re: NPI addres
Hi Dylan,
I use Microblase and via PLB and RS232 I can read positions of DDR2 after writing via NPI. I attach the mhd file, I hope that will help to You to help me to solve this problem. Please correct me if I am wrong, when I have DDR2 and baseaddr is e.g. 0x90000000 and I want to write to addres 0x90000005, the NPI_ADDRES must be 0x00000005, yes?
Tx in advance,
Petr
Re: NPI addres
Petr,
You cannot write to address 0x9000005 since it is not aligned on a word or doubleword boundary.  This is an illegal operation to NPI, but is legal to PLB.
See the MPMC datasheet in the NPI PIM section for all the restrictions on using NPI (there are quite a few of them).
Dylan
Visitor dosman79
Re: NPI addres
Hi Dylan,
I tryed to change the Address to 0x00000002, but no change. I don't understand to this. Please, can You send to me a small part of working project, I am interesting in mhs file and vhd file with writing throught NPI to DDR2. Be so kind and if it is possible send it to petr_dosek@email.cz  I hope it will help me to make next step to finish my problem.
Thank You for Your attention.
Petr
Re: NPI addres
Address 0x2 is also not aligned to the width of the NPI interface. Try address 0x0.
If you still have problems, see the MPMC datasheet, in the NPI PIM section for a long list of requirements.
Re: NPI addres
Hi Petr
Why not just use 0x0 as the start point.
NPI transactions must have the PIM<Port_Num>_Addr address aligned to the size of the transactions, as spec-
ified by PIM<Port_Num>_Size. For example, a 32-word burst must have PIM<Port_Num>_Addr[6:0] set to 0.
For other start address, we need to check the burst length and so on.
Visitor dosman79
Re: NPI addres
Hi Josh
I want to jump to different addr, because my program is bigger and I use DDR2(in linker script) to load the program to XC5. When I use starting poit 0x0 then I kill my program.
Re: NPI addres
Petr
It's fine to not start with 0x0, but the address you start with should be "PIM<Port_Num>_Addr address aligned to the size of the transactions" , the 0x2 doesn't follow this rule.
Another workaround for you, is just start with 0x0, and put your other code and the other range, you can change this with linkerscript, as PLB can handle the un-aligned issue, this could help you overcome the problem.
Visitor dosman79
Re: NPI addres
Hi Josh,
sorry for long delay I was in a hospital. I follow your advice to change position of my code. Since I didnt know other way, I have tried to change location manually, but without success. I think I am doing something wrong. I have opened *.ld file and  I changed this:
Origin
   DDR2_SDRAM_MPMC_BASEADDR : ORIGIN = 0x50000000, LENGTH = 0x10000000
After
   DDR2_SDRAM_MPMC_BASEADDR : ORIGIN = 0x59000000, LENGTH = 0x07000000
I suppose that this changes base address of my code to  0x59000000 and I can access by NPI addresses from 0x50000000 to 0x58ffffff without worry overwritting my code. Is it true?
Size of my code:
mb-size aaaaa.elf
   text   data    bss    dec    hex filename
 175840   1492 2055776 2233108 221314 aaaaa.elf
mb-size test.elf
175840   1492 2055776 2233108 221314 test.elf
size of test.elf is 638 304 Bytes
When I load and run the code:
MicroBlaze Processor Configuration :
Version............................7.20.d
Optimization.......................Performance
Interconnect.......................PLBv46
MMU Type...........................No_MMU
No of PC Breakpoints...............1
No of Read Addr/Data Watchpoints...0
No of Write Addr/Data Watchpoints..0
Instruction Cache Support..........on
Instruction Cache Base Address.....0x50000000
Instruction Cache High Address.....0x5fffffff
Data Cache Support.................on
Data Cache Base Address............0x50000000
Data Cache High Address............0x5fffffff
Exceptions  Support................off
FPU  Support.......................off
Hard Divider Support...............off
Hard Multiplier Support............on - (Mul32)
Barrel Shifter Support.............off
MSR clr/set Instruction Support....on
Compare Instruction Support........on
Data Cache Write-back Support......off
4
System Reset .... DONE
Downloading Program -- E:/EDK_projekty/NPI/SDK/SDK_Workspace/aaaaa/Debug/aaaaa.elf
section, .vectors.reset: 0x00000000-0x00000007
section, .vectors.sw_exception: 0x00000008-0x0000000f
section, .vectors.interrupt: 0x00000010-0x00000017
section, .vectors.hw_exception: 0x00000020-0x00000027
section, .text: 0x59000000-0x59029ba3
section, .init: 0x59029ba4-0x59029bcb
section, .fini: 0x59029bcc-0x59029beb
section, .rodata: 0x59029bec-0x5902aebf
section, .data: 0x5902aec0-0x5902b47b
section, .ctors: 0x5902b47c-0x5902b483
section, .dtors: 0x5902b484-0x5902b48b
section, .eh_frame: 0x5902b48c-0x5902b48f
section, .jcr: 0x5902b490-0x5902b493
section, .bss: 0x5902b498-0x592192f7
section, .heap: 0x00000050-0x0000404f
section, .stack: 0x00004050-0x0000804f
Setting PC with Program Start Address 0x00000000
Safe Mode is disabled.
Setting breakpoint at 0x5901a9f4
Everything looks good,but the program doesnt write any text to the terminal as it should. Do You have any other advice to solve my problem??
Re: NPI addres
Actually I begin with NPI few days ago, I am still trying to understand how it works and the Tools available for develop it. I am new with Xilinx.
I just have a question for you, instead than an answer.
Why do you have 2 clocks in your system, 1 at 100MHz for the PLB and other at 200MHz for the MPMC?
Thank you.
DABG
Re: NPI addres
You need to have two clocks since you are attaching the MPMC to the DDR memory which is double rate.
This means that the system and user logic is clocked at 100MHz and the part between MPMC and DDR at 2x system clock which is 200MHz.
Greetings, Mariusz
Mariusz Grad.
Re: NPI addres
This code will not start (execute) at all.
In your output you can see:
Greetings, Mariusz
Mariusz Grad.
