Observer otod3r
Nandflash not working on a zynq-based board
Hi all,
I have a custom board with XC7Z020 and MT29F8G08(nandflash,x8,8Gbit).
MT29F8G08 is in the zynq supported list(http://www.xilinx.com/support/answers/50991.htm),but it does not work.(e.g.,I enter "nand erase.chip" in u-boot ,then zynq resets itself.)
I find that MT29F4G08(nandflash,x8,4Gbit) work fine on my custom board.
Anybody got any idea?
thx
Observer otod3r
Re: Nandflash not working on a zynq-based board
Thank you for your reply.My uboot dosenot support MT29F8G08.The detail number is MT29F8G08ABABAWP.
It I've read the datasheet correcly, the MT29F4G08 has a single die and the MT29F8G08 has two die stacked.
I'm not sure whether the two die share a CE input or whether they are separate.  That detail is in the latter letters of the part number, which you did not supply in your post.  If they are separate, did you connect both of them (and to what)?
BTW, There are four CE inputs defined (by JEDEC) for that footprint (assuming BGA).
Allan
Observer otod3r
That part number decodes as:
SLC Flash
8Gbit
x8 bus
Single die / single CE / single RB
3.3V
Async interface
TSOP
So it doesn't have two stacked die as I thought earlier.  That makes it unlikely to be a hardware problem, and the only difference between the 4G part and the 8G part has to do with the way the array is addressed.
When I compare the block diagrams for the two (4G and 8G) devices:
Page size: 2112 (2k + 64) Bytes vs 4320 (4k + 224) Bytes
Pages per block: 64 vs 128
Blocks per plane: 2048 vs 1024
Blocks per device: 4096 vs 2048
Planes per device: 2 vs 2
I speculate that the different page size is the one that is causing the problem.
Allan
