No voltage convertation
Hello everyone,
I am using XADC in event-driven mode and do not get any converted voltages.
If I take the same code, disable event-driven mode. Everything is working fine.
Did I forget something important, or is someone having an advice for me?
Re: No voltage convertation
Hi @helplessguy,
Which application are you talking about?
Praveen
I want to read the XADC in event-sampling mode. and when I read with XSysMon_GetValue() it always returns 0.00V, or another constant value
