Visitor new_student
OSERDES2 simulation - no output
I'm currently working with the OSERDES of a Zynq. If I'm using the SelectIO wizard, everything works fine.
But for my current project I need to use the OSERDES2 directly in my VHDL files. So I used the templates and the reference design files from XAPP585. But if I try to run my testbench, the outputs stay in state 'X' all the time.
Since the clocks and the reset work as expected during simulation, I think I made a mistake with the OSERDES2.
May you pleas have a look at the attached VHDL file, please?
Best regards
Visitor new_student
Re: OSERDES2 simulation - no output
it seems like I found the Problem. If I assign the clock after some ns it works almost like expected.
Except that the serialised data is not in sync with CLKDIV. So I made a project with a minimalistic block design, including a clocking wizard and the selectIO core. Serialisation is set to SDR with a factor of 8. The DIVCLK is forwarded as well. CLK is set to 800MHz and CLKDIV to 100MHz; both via the clocking wizard.
Running the simulation results in a strange behavior. The clock is forwarded correctly and the data is serialised but the data is not in sync with the forwarded clock (CLKDIV)?
What am I missing here?
Attached you will find the minimalistic design.
Best regards.
