PL load error via fpgautil on zcu111, zynqmp_clk_divider_set_rate() set divider failed
Hi all,
I am trying to load the PL portion of my design through FPGA manager, which for the moment is a test design with only a few gpios and a ddr4 memory ip core. My project compiles and I've generated the bitstream, and am able to do some standard LED blinks through a baremetal driver through the SDK.
Now I wanted to load the PS onto a linux system and try using FPGA manager to load the PL afterwords. I followed the main steps, petalinux-create -> petalinux-config with my .hdf file and fpga manager selected, as well as petalinux-build and petalinux-package.
After this, I put my BOOT.bin and image.ub on an SD card and am able to boot my file system and kernel.
Now, when I want to load the PL, I do an scp of the .bit.bin and the .dtbo files that petalinux generated for my project, namely, the files in
/project_dir/build/tmp/sysroots-components/zcu111_zynqmp/fpga-manager-util/lib/firmware/base/design.bit.bin, and base.dtbo
Now that I have it on my machine, I try a fpgautil -b design_1_wrapper.bit.bin -o base.dtbo , and get the following message through the console:
root@xilinx-zcu111-2018_3:~/temp_files# fpgautil -b design_1_wrapper.bit.bin -o base.dtbo
[ 427.020618] fpga_manager fpga0: writing design_1_wrapper.bit.bin to Xilinx ZynqMP FPGA Manag
er
[ 427.275452] zynqmp_clk_divider_set_rate() set divider failed for pl0_ref_div1, ret = -13
Time taken to load DTBO is 266.000000 Milli Seconds
DTBO loaded through zynqMP FPGA manager successfully
I receive this message regardless of trying another projects hardware files, also created through the petalinux interface (I'm using petalinux 2018.3).
Does anyone have any idea as to why this is? I can also provide my hardware design if needed, but it is not much more than a ZynqMP+, ddr4, a bram and a few gpios.
Re: PL load error via fpgautil on zcu111, zynqmp_clk_divider_set_rate() set divider failed
This flow is covered here:
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841645/Solution+Zynq+PL+Programming+With+FPGA+Manager
If your use case is to not have the PL bitstream in the BOOT.BIN (ie if booting over tftp for example), then you can do the following:
Creating Image in Petalinux 2018.3:
  • petalinux-create -t project -s <path to BSP>.bsp
  • cd <plnx project>
  • petalinux-config
  • petalinux-config -c kernel
    • config as shown here
  • petalinux-build
  • cd images/linux
  • petalinux-package --boot --u-boot
I have a helper script that you can use (attached here)
Creating BIN, and DTO:
Launch XSCT, and source the attached helper script. Run the commands below:
  • generate_dts <path to HDF>.hdf
  • bit2bin <path to HDF>.hdf
Testing on Hardware:
Place the BOOT.BIN, image.ub, design_1_wrapper.bit.bin, pl.dtbo onto an SD card and boot:
Use the commands on the wiki to test:
Hi Stephen,
Thank you for your response, however, I noticed you also received the zynqmp_clk_divider_set_rate() set divider failed for pl0_ref_div1, ret = -13 error as I did.
This seems to affect how the clock works for certain IPs such as the GPIO.
Also, do you get this set divider failed for pl0_ref_div1 message even when using FPGA_Manager (meaning the fpgautil command) ?
Did you end up figuring out the reason for this?
I also ran into the same thing using fpgautil.
Nope still didn't find the reason
@az23
I tried the latest release 2019.1. The issue seems to go away now. I use zcu102 but I suggest you give it a try.
I guess there was a regression in the previous version.
Did FPGA Manager work without any issues for you for petalinux 2019.1? Trying a simple design I get the following message:
/lib/firmware/base# fpgautil -b design_1_wrapper.bit.bin -o base.dtbo
[ 51.852643] fpga_manager fpga0: writing design_1_wrapper.bit.bin to Xilinx ZynqMP FPGA Manager
[ 51.927141] fpga_manager fpga0: Error while writing image data to FPGA
[ 51.940380] fpga_region region0: failed to load FPGA image
[ 51.945881] OF: overlay: overlay changeset pre-apply notifier error -22, target: /fpga-full
[ 51.954226] OF: overlay: overlay changeset pre-apply notify error -22
[ 51.960671] create_overlay: Failed to create overlay (err=-22)
I actually went with a different route. I used Vivado and just compiled the example design for the board. Then, linked it to the build. I loaded that one and it works. It's basically allowing user to control gpios
