Visitor jcompadr
PL shared interrupt not been activated
Hi, I am trying to activate a shared interrupt in the processing system. It will be activated by a signal created in my custom IP, which will be active for some time.
I am able to use a private interrupt (Core0_nFIQ), the interrupt handler function is executed correctly when my custom signal is activated. However I am interested in using a shared interrupt, but when I conect my signal to this shared interrupt, after configuring it in the SDK, it does not seem to work.
When I try to use the shared interrupt, in addition to the configuration for the private one, I have configured "XScuGic_SetPriorityTriggerType" and "XScuGic_InterruptMaptoCpu" when using the shared interrupt. I have also changed the interrupt "ID to XPS_FPGA0_INT_ID"
Here is my Block Design:
And my C code to configure the interrupt:
#include <stdio.h>
#include "platform.h"
#include "xil_printf.h"
#include "myip_bram_pl_controller.h"
#include "xil_io.h"
#include "xparameters.h"
#include "Xscugic.h"
#include "Xil_exception.h"
#define FPGA_INT XPS_FPGA15_INT_ID//XPS_IRQ_INT_ID//
#define INTC_DEVICE_ID XPAR_SCUGIC_SINGLE_DEVICE_ID
static void FPGAIntrHandler(void *CallBackRef);
static void SetupInterruptSystem(XScuGic *GicInstancePtr, u32 *FPGAPtr, u16 FPGAIntrId);
static XScuGic Intc; //GIC
static u32 FPGA;
void * addr = (void *) XPAR_MYIP_BRAM_PL_CONTROL_0_S00_AXI_BASEADDR;
int main()
u32 * destination;
init_platform();
printf("Configuring interrupt\n\r");
destination = (u32 *)XPAR_AXI_BRAM_CTRL_0_S_AXI_BASEADDR;
MYIP_BRAM_PL_CONTROLLER_mWriteReg(XPAR_MYIP_BRAM_PL_CONTROL_0_S00_AXI_BASEADDR,MYIP_BRAM_PL_CONTROLLER_S00_AXI_SLV_REG0_OFFSET,0); //enable
SetupInterruptSystem(&Intc,&FPGA,FPGA_INT);
while(1){}
cleanup_platform();
return 0;
int Status;
XScuGic_Config *IntcConfig; //GIC config
//initialise the GIC
IntcConfig = XScuGic_LookupConfig(INTC_DEVICE_ID);
XScuGic_CfgInitialize(GicInstancePtr, IntcConfig,
IntcConfig->CpuBaseAddress);
//Perform a self-test to ensure that the hardware was built correctly. ADDED
Status = XScuGic_SelfTest(GicInstancePtr);
if (Status != XST_SUCCESS) {
print("GIC SelfTest Failed\n\r");
return XST_FAILURE;
Xil_ExceptionInit();
//connect to the hardware
Xil_ExceptionRegisterHandler(XIL_EXCEPTION_ID_INT,
(Xil_ExceptionHandler)XScuGic_InterruptHandler,
GicInstancePtr);
//set up the timer interrupt
XScuGic_Connect(GicInstancePtr, FPGAIntrId,
(Xil_ExceptionHandler)FPGAIntrHandler,
(void *)FPGAPtr);
//ADDED for shared interrupt
XScuGic_SetPriorityTriggerType(GicInstancePtr, FPGAIntrId, 8, 0b11);
XScuGic_InterruptMaptoCpu(GicInstancePtr, 0, FPGAIntrId);
//enable the interrupt for the Timer at GIC
XScuGic_Enable(GicInstancePtr, FPGAIntrId);
// Enable interrupts in the Processor.
Xil_ExceptionEnableMask(XIL_EXCEPTION_ALL);//Xil_ExceptionEnableMask(XIL_EXCEPTION_IRQ); //Xil_ExceptionEnable();
printf("Interrupt Set Up\n\r");
printf("FPGA Interrupt Event\n\r");
Tags (3)
