Visitor 511225
PORT CLKOUT1
I have MicroBlaze and for user peripheral I need other clk than sys_clk_s. I want to use clock_generator_0 and in this one
PORT CLKOUT0 = sys_clk_s
PORT CLKOUT1 = clock_generator_0_CLKOUT1
However, I do not know how can I get clock_generator_0_CLKOUT1 in periferie. Could you help me, please.
Kral
Re: PORT CLKOUT1
When you configure the clock generator, you can connect the CLKOUT1 signal to the ports that exist in the drop down list.
Or you can directly  modify the MHS
PORT CLKOUT1 = clock of the peripheral.
Rgds
Visitor 511225
Re: PORT CLKOUT1
Could you help me in more detail, please?
Already after the configuration of the clock generator the following line appeared in file MHS
PORT CLKOUT1 = clk_div1
In periphery I have
--USER ports added here
   clk_div1      : in   STD_LOGIC;
Nevertheless, I still result in the error
Dangling pins on
  block: clock_generator_0........
Visitor 511225
Re: PORT CLKOUT1
I think that it is also necessary to modify file my_periphery.MPD and in MHS file instance my_periphery, however, I do not know how to do this.
