PS - PL communication
Hi sir,
I have connected different peripherals(DDC(1553-B) chip, Digital inputs, Digital outputs,UART) at PL side. but i want to control it by using PS. For that i have written AXI slave VHDL program.Master AXI Reading and writing results are displaying an PS-UART on host PC.
When AXI master reading --->  The address asserting by master AXI is fine.
                                           --->  The Data asserting by Slave(VHDL logic at PL side) is delaying 500 ns. (Reading DDC chip and corresponding data asserting on AXI slave)
* may be processor does not waiting that time , not getting result at HOST PC.
Then i have taken "AXI lite - APB" bus bridge to communicate PL but vivado not assigning the address to AXI-APB bridge. but when i am making it to external it is assigning the address. After assigning the address  i am making my APB logic in PL.but no results have observing in host PC.
* Please suggest the best way to communicate PL and PS.
*What is the maximum Processor( AXI master) wait time while reading from AXI slave?
Kasarla Ganesh
Re: PS - PL communication
Keep in mind that you are using Xil_In32 and Xil_Out32 which are exercising 32bit accesses. So your print format should be 0x%08x, temp should be unsigned int or better yet, u32, and your offset should increment by 4 due to the 32bit accesses.
Mentor watari
Mentor
Hi @ganeshpatel
I don't have any answers. But I suggest to do simulation with ZYNQ VIP by xsim to clarify the route cause and to estimate a wait time.
Would you try it ?
https://www.xilinx.com/support/documentation/ip_documentation/processing_system7_vip/v1_0/ds940-zynq-vip.pdf
Best regards,
Hi sir,
thanks for replying me. I tried what you suggested, but not in XSIM, on Hardware tried.finally i concluded its not delaying problem.
its writing problem of AXI master. i follwed below code SDK.
my base address is 0X8000_0000. If i write base adress as  0X8000_0000 and offset as 0x0. then i am able to writing it and also
able to reading it. But if increase my offset address then writing and reading was not performing.
 * if it is only writing and reading of a base address.
1.Example iteration code :
i= 0;
     while (1) {
      set_custom_ip_register(0x80000000, i, 0xa5a5); //set_custom_ip_register(base address, offset address, Data);
      xil_printf(".\r\n");
      temp5=get_custom_ip_register(0x80000000, 0x1); //get_custom_ip_register(base address, offset address);
      printf("Register 3 = 0x%02X\n\r", temp5);
        xil_printf("2\r\n");
conclusion : writing and reading success full.
2.Example iteration code :
    /* receive and process packets */
     while (1) {
         set_custom_ip_register(0x80000000, 0, 0xa5a5); //set_custom_ip_register(base address, offset address, Data);
        temp3=get_custom_ip_register(0x80000000, 0);    //get_custom_ip_register(base address, offset address);
        printf("Register 3 = 0x%02X\n\r", temp3);
//---------up to here reading and writing fine---------------------
//------------if i increase offset address then its not performing
         set_custom_ip_register(0x80000000, 0x2, 0xc5c5);
        temp4=set_custom_ip_register(0x80000000, 0x4, 0xe5e5);*/
         printf("Register 3 = 0x%02X\n\r", temp4);
conclusion : writing and reading address failed at offset address >1.
regards
Kasarla Ganesh
Hi sir,
Thanks  for your reply, i got the solution.
Thanks & Regards
Ganesh Kasarla
