Observer 6l20
PS to PL interrupt port size problem
Hi all,
on Vivado 2014-1 (but it was the case for previous version), I'm trying to connect 2 interrupts to PS.
In the processing system configuration, under interrupt, I have enabled "Fabric interrupt" and "IRQ_F2P[15:0]" under PL-PS part, as following:
So my understanding is that I should have 16 interrupts lines available from PL part.
But when validating these setting, I got only a 1 bit interrupt vector available :
If I try to connect many interrupts or a 2-bits interrupt vector outgoing of my custom-IP, I have a warning of size mismatch at the synthesis that tells me that only the LSB will be connected, others will be left unconnected.
Is there something else to configure to have more than 1 PL-PS interrupt ?
Thanks for your help.
Sylvain
Scholar sampatd
Re: PS to PL interrupt port size problem
You will need to use the concat IP to connect more than 1 PL-PS interrupt.
Follow the steps mentioned in the AR below, and you should be good to go:
http://www.xilinx.com/support/answers/58942.html
Scholar sampatd
Observer 6l20
Hello sampatd,
thanks a lot for your reply, it works fine.
Sylvain
Visitor jms_on_x
Hello sampatd,
I have seen your reply to this issue a few times (links below).  My question is, what if I am instantiating the ps7 instance in RTL.  After customizing the PS7 IP from the IP catalog and then generating the IP, the .VEO file contains the line:
  .IRQ_F2P(IRQ_F2P),                                    // input wire [0 : 0] IRQ_F2P
How can I connect a 16-bit input bus to this port?  If I instantiated a concatenation module in RTL, I don't see how it would fix or affect the sizing of the IRQ_F2P port on the PS7 instance.
Thanks for your help,
-- Joel
http://forums.xilinx.com/t5/Embedded-Processor-System-Design/Where-is-16-bit-shared-interrupt-port-IRQ-F2P-15-0/m-p/353845/highlight/true#M9378
http://www.xilinx.com/support/answers/55703.htm
For RTL you can set the following property on the IP through TCL, you can't do it in the customisation GUI:
set_property CONFIG.PCW_NUM_F2P_INTR_INPUTS {16[get_ips processing_system7_0]
