Visitor m_kalburgi
Problem in running the TEMAC code targetted for spartan1800 3ADSP
I have the code for "Local Link Temac with SDMA and CSO" targetted for spartan1800 3ADSP eval board. I am using this code on my own board which is having spartan1800 3ADSP, ETHERNET PHY 83865 and SDRAM. I am using SDRAM for the DMA. I have made the cjhnges accordingly in the code for the SDRAM in MPMC module and also other changes such as ucf etc. I have tested the SDRAM using the Test Memory application successfully. The execution of RXTest/TxTest application was done from the SDRAM.
Also I have set the IP address of the PC as 192.168.1.50 and gateway as 192.168.1.1 . I am using cross-over cable for PC to board interface.
While running the RXTest/TxTest the code stops executing after printing the following message on the hyperterminal.
-----lwIP Transmit Test [Board -> Host] ------
To perform TCP TX bandwidth calculation, run iperf from your host machine as:
iperf -s -i 2 - p 2000
Board should have IP 192.168.1.50 (can be changed in txperf.c)
Board IP: 192.168.1.105
Netmask : 255.255.255.0
Gateway : 192.168.1.1
XLlTemac detect_phy: PHY detected.
I will be happy if I could get any suggestion on the above problem.
Thank you,
Manish Kalburgi,
VLSI Engineer,
Wavelet Group, Pune-21 India.
