Visitor hongyan
Problem of using Flash_Initialize on ML605
I have some problem when use XFlash_Initialize on ML605 under ISE12.1
I have a MicroBlaze, UART, xps_mch_emc and other necessary components in the XPS system. Then I exported the design to SDK.
I wrote the following code:
Without calling  XFlash_Initialize, I can print out the hello on my screen. But with the XFlash_Initialize, the program just crash without any info. I went to the debug mode, it just said:"No source available for "" ".
Can you give me some suggestion? If you need any other files, please let me know.
Thank you very much for your help,
Shirley
my application code:
int main (void) {
int result;
XFlash TestFlash;
XFlash* PTestFlash;
xil_printf("hello!\n");
PTestFlash = &TestFlash;
result = XFlash_Initialize(&TestFlash);
if(result != XST_SUCCESS)
xil_printf("flash initialization unsuccessful result = %d\n", result);
The following are from the xparameters.h
/* Definitions for peripheral MEM_BUS */
#define XPAR_MEM_BUS_MEM0_BASEADDR 0x86000000
#define XPAR_MEM_BUS_MEM0_HIGHADDR 0x87FFFFFF
The above is the address for xps_mch_emc.
#define XPAR_XFL_DEVICE_FAMILY 1
#define XPAR_XFL_PART_MODE 2
#define XPAR_XFL_NUM_PARTS 2
#define XPAR_XFL_PART_WIDTH 2
#define XPAR_XFL_BASE_ADDRESS 0x0
#define XPAR_XFL_PLATFORM_FLASH 0
Shirley
Re: Problem of using Flash_Initialize on ML605
have you selected the Flash library in OS&Libraries settings?
