Visitor cesarcf
Problem with AXI-Stream in a DDR-DMA-Ethernet dataflow
My idea is about sending data from a DDR Memory through the AXI 1G/2.5G Ethernet Subsytem IP using Stream transfers with a DMA block. The FPGA is connected to a PC (via Ethernet cable) in which Wireshark is running in promiscuous mode.
The problem is that Wireshark does not received anything from the FPGA. Debugging the system I found that the AXI-Stream link between Ethernet and DMA blocks does not move any data. By means of an ILA connected to this link I watch that TKEEP and TVALID signals are asserted but the other ones (TREADY, TDATA, TLAST) are not.
The block diagram is shown below:
I did not find any design example with this configuration and I think that my problem is more related to software configuration than hardware, or maybe I am wrong and the block diagram is not correct.
I am using the following code:
#include "xil_printf.h"
#include "xparameters.h"
#include "xaxiethernet.h"
#include "xaxidma.h"
#define DDR4_BASEADDR (XPAR_AXI_BRAM_CTRL_0_S_AXI_BASEADDR)
#define SIZE (64)
XAxiEthernet MAC_GigE;
XAxiDma DMA_GigE;
int main(){
/***** Variables declaration *****/
int Status;
int ddr[SIZE];
u8 MAC_addr[6] = {0x00, 0x0A, 0x35, 0x33, 0x33, 0x33};
/* IPs configuration */
XAxiEthernet_Config *MacCfgPtr;
XAxiDma_Config *DmaConfig;
/* Get the configuration of AxiEthernet hardware */
MacCfgPtr = XAxiEthernet_LookupConfig(XPAR_AXIETHERNET_0_DEVICE_ID);
/* Get the configuration of DMA */
DmaConfig = XAxiDma_LookupConfig(XPAR_AXI_ETHERNET_0_DMA_DEVICE_ID);
* Initialize AXIDMA engine. AXIDMA engine must be initialized before
* AxiEthernet. During AXIDMA engine initialization, AXIDMA hardware is
* reset, and since AXIDMA reset line is connected to AxiEthernet, this
* would ensure a reset of AxiEthernet.
Status = XAxiDma_CfgInitialize(&DMA_GigE, DmaConfig);
if(Status != XST_SUCCESS) {
xil_printf("Error initializing DMA\r\n");
return XST_FAILURE;
/* Disable interrupts, we use polling mode */
XAxiDma_IntrDisable(&DMA_GigE, XAXIDMA_IRQ_ALL_MASK, XAXIDMA_DEVICE_TO_DMA);
XAxiDma_IntrDisable(&DMA_GigE, XAXIDMA_IRQ_ALL_MASK, XAXIDMA_DMA_TO_DEVICE);
/* Initialize AxiEthernet hardware */
Status = XAxiEthernet_CfgInitialize(&MAC_GigE, MacCfgPtr, MacCfgPtr->BaseAddress);
if (Status != XST_SUCCESS) {
xil_printf("Error in initialize");
return XST_FAILURE;
XAxiEthernet_SetMacAddress(&MAC_GigE, MAC_addr);
XAxiEthernet_SetOptions(&MAC_GigE, XAE_TRANSMITTER_ENABLE_OPTION);
XAxiEthernet_Start(&MAC_GigE);
// Checking functions
xil_printf("SGMII: %d\n\r", XAxiEthernet_GetPhysicalInterface(&MAC_GigE) == XAE_PHY_TYPE_SGMII);
xil_printf("Is started?: %d\n\r", XAxiEthernet_IsStarted(&MAC_GigE));
xil_printf("IsDma: %d\n\r", XAxiEthernet_IsDma(&MAC_GigE));
xil_printf("IsMcDma: %d\n\r", XAxiEthernet_IsMcDma(&MAC_GigE));
xil_printf("DMA has Scatter-Gather: %d\n\r", XAxiDma_HasSg(&DMA_GigE));
xil_printf("\n\n\rLaunching program...\n\r");
xil_printf("Before: ");
for(int i = 0; i < SIZE; i++)
xil_printf("%d ", ddr[i]);
*ddr = DDR4_BASEADDR;
ddr[i] = i+1;
xil_printf("\n\rAfter: ");
xil_printf("\n\r");
xil_printf("%d\n\r", XAxiDma_SimpleTransfer(&DMA_GigE, (UINTPTR)ddr, SIZE, XAXIDMA_DMA_TO_DEVICE));
return 0;}
Another problem comes up after running this application: the program gets stuck within "XAxiEthernet_CfgInitialize", while executing "XAxiEthernet_Reset" function. If I comment this instruction, the program finishes correctly: XAxiDma_SimpleTransfer returns 0, but it does not send anything, indeed.
Maybe I am forgetting something during the configuration, but I wrote the code following the examples provided by Xilinx. Do you have any idea this design is not working?
Thank you in advance!!
Extra info:
KCU105 (KU040)
Vivado 2018.1
