Problem with the IIC IP clock setting
For unclear reason can't modify in Vivado 2017.4 the  SCL Clock from 100KHz to 400Khz. AXI clock in IP setting is 100MHz.
In the simulation I see  the IIC IP input AXI clock frequency is 100MHz but SCL Clock still as default 100KHz.
Can you explain?
Re: Problem with the IIC IP clock setting
Kindly confirm are you using PS or PL IIC.
Venu
You didn't tell us which device you are using or whether this is from the PL or PS side of a Zynq.  If it is the PS side of a Zynq, this is fromthe Tech Ref Guide for the Ultrascale+
The I2C controllers can function as a master or a slave in a multi-master design. They can
operate over a clock frequency range up to 400 kb/s.
This is probably limited by the drive strength of the pins.
Venu
