Problems with MPMC on Virtex5 device
I have a board from HiTechGlobal with Virtex 5 FX200T Devices.
I must use the external memory (SODIMM MT16HTF25664HY-667E1) shared between 2 PPCs.
I use the MPMC 6.02.a with the integrated MIG interface connected via PLB (@100MHz) to 2 PPCs(@400MHz).
During the MPMC settings I have:
1) I run the BITSTREAM generation and the process ends without errors
2) I create the SDK application
3) I initialize the MPMC interface without errors:
MiaMpmc_Config = XMpmc_LookupConfig(XPAR_MPMC_0_DEVICE_ID);
if (XMpmc_CfgInitialize(&MiaMpmc, MiaMpmc_Config, MiaMpmc_Config->BaseAddress)!= XST_SUCCESS)
{ xil_printf("\r\nUnable to initialize MPMC");
while (1);
4) I run the MPMC Self Test without errors:
if (XMpmc_SelfTest(&MiaMpmc)!= XST_SUCCESS)
{ xil_printf("\r\nSelf Test MPMC failed");
while (1);
But I have the following problem:
if I try to access to the memory via application the memory does't respond.
I use the following code:
Read_Value=Xil_In32(XPAR_MPMC_0_MPMC_BASEADDR);
Xil_Out32(XPAR_MPMC_0_MPMC_BASEADDR, 0x12345678);
And Read_Value assumes always the same value (0xwith or without the SODIMM memory (0xa5a5a5a5)
Can you help me to resolve the problem?
I use SDK 12.4
Re: Problems with MPMC on Virtex5 device
Since this is a embedded applications issue, this question would be best answered in the embedded forums. I'll send this over there instead
have your checked the mpmc init_done signal?
does it assert?
@joshualu: No the init_done signal remains low.
